general system questions (h.u, speaker installation, subz+amp + mayb more)
Old Sep 20, 2005
civicxtc's Avatar
civicxtc is an unknown quantity at this point
ive got a 95 civic sedan with a sony xplod cdx-l490b deck but im going to replace that with a pioneer deh-p4700mp or 6700mp.
now bcus my parents bort the sony xplod h.u and they are clueless about car audio, my question is can i use the aftermarket mounting kit & wiring harness to use on the pioneer or wud i need new ones that are specifically made for the pioneer decks?? (i assume all the installation aceesories i need is the kit & wiring harness but if i need more plz inform)
also, to remove the sony xplod i need release keys but my parents lost them, is there any way i can still remove it with tools or sumthin?? i cant seem to pull it out n i dont wanna take it to a installer wen i cud do everything myself n save sum money, thanks
Old Sep 20, 2005
Tragedy's Avatar
skate or die
Im not sure of the other deck mounting up in the old setup, but the locks can be opend with a knife or something equvalent. I know it sounds ghetto, but it has worked before.
Old Sep 20, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
U can order the keys online. The harness r interchangable but U will have to rewire it the Pioneer.
Old Sep 20, 2005
ruckerheadz's Avatar
ruckerheadz is an unknown quantity at this point
u will have to rewire it to the pioneer like the guy befor said, the harness is only used so u dont have to cut into the cars factory wiring and easy to replace the stock hu when u want to if need be. as long as the new pioneer is the same din size as the sony u shouldnt have any problem, use a knive or sumthin to release the cage, its just thin metal so its easy to bend back if u dont get it right and just rip it out lol..
Old Sep 22, 2005
civicxtc's Avatar
yup i knew id have to re-wire myself but i still cant seem to pull the h.u out hahah ive put a knife in top n bottom, slid it left n rite, into the sides, up n down but doesnt seem to do anythin so im just going to leave that for a pro installer to worry about
neway im goin to replace the speakers in my doors with 6 1/2''s. b4 i ask anythin, issert normal that civics came with a stock 6'' in the right door n a stock 4'' in the left?? cus mine does, jus wonderin cus it seems honda fort id b dumb n that i wudnt notice, but doesnt matter since im goin to replace em
k, cus i got 4'' in left, id need speaker brackets/adapter plates?? jus need to know if thats the correct term for wat im lookin for n if there are any other names for it - cus wen i went to buy speakers for rears at a retail car audio store n askd for wiring adapters/harness the guy sed there was no such thing, i was thinkn hmmm ok then but since i didnt need em at the time i walkd away - bloody foolz who dunno anthin bout car audio, then agen he cudve been right hahah
hmmm ive rambled enuff, basically:
1: i need speaker brackets/adapter plates, correct n any other lingo for em??
2: shud i get speaker baffles while im there or issert overkill??
Old Sep 22, 2005
joescivic02's Avatar
Abercrombie and Fitch
wow........ 4 inch? 6 inch? never heard of those numbers before.......... if you have a coupe, you have 6 1/2s in the front and 6x9s in the back........ sedan equals 6 1/2s all around.......... you might need spacers it depends............ go with alpine type s's and you wont they are the best bang for the buck..
Old Sep 23, 2005
civicxtc's Avatar
thnx
spacers - same thing, diff name for speaker brackets/adapter plates??
speakers baffles - worth gettn??
also in the future ill be gettn a pioneer tsw306c (12'' sub) and wud like to know wat kind of amp i wud need to run it (800w, 1000w, 300rms x4, 250rmxs x4 blah blah etc etc). keep in mind that i wud like to have my fronts running off 2 channels so a 4-channel amp wud b preffered BUT im not planning on winning comps or tryna let the whole block know i have a sub, jus clean, clear n loud for me n my passengers sooooo wud i b betta off (finiancially) if i just let all 4 speakers run off the deck (which will b a pioneer deh-p5750mp) n gettn a monoblock amp?? if so, wud also like amp specs for that
also, im not sure if its relevant or not but, im not the type of person who (only in a car) likes to have thier music generally 'in front', bcus i go clubbing alot i guess im another one of those who like to b 'surrounded' by their music like ina club. dunno if this will help decide whether i shud amp the fronts or rears/have only my sub amped (therefore obviously ill b gettn mono amp) but giving more details about wat i want in my car audio is alwaiz betta for u guyz =]
Old Sep 23, 2005
your best bet is too use 2 channels for the component speakers in the front and combine another 2 channels of the amp for the sub..... therefore i would reccomend a 4 channel amp...... itll be a decent sound system.....
Old Sep 24, 2005
civicxtc's Avatar
that sounds good, but ive alredy bought coaxils for fronts so i figured amping them arnt worth it - since their coaxils & 35rms but if amping them is still suggestd, then plz do so. yes i wud amp compenents like u sed joecivic but rite now i dont have the funds to do so
ive decided for now to - unless suggestd to amp fronts - to jus have all 4 speakers run off deck then add a sub+amp in future. soo, assuming i still go for that pioneer tsw306c, shud i get a monoblock amp or 2channel amp to power it?? i dont knoe much about amps (250wx1 @2ohm, sumthin@4ohm, sumthin@sumthin, 14.4v, 12v etc etc & all otha amp specs im uneducated about) but i figured bcus 2-channel amps r generally cheaper, shud i jus bridge 2 channels or wud buying a mono be worth the extra money. my budget for sub+amp+installation equipment needed(including box+dynamat)+installation is $1100
Old Sep 24, 2005
jay78's Avatar
jay78 is on a distinguished road
if are not gone use that sony wireharness then do this
aftermarket wireharness connect to the stok harness....cut the aftermarket harness then match color with poineer thats how i did mine.....i did that cuz my poineer has extra wires like e-brake and backup wire ,,,,
do this only if are naver gone use this harness agin...
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Youshoe
May 22, 2015 09:36 PM
cloudguy
Apr 28, 2015 05:02 AM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
viper775
Nov 8, 2001 09:14 PM
