which wire do i connect the remote wire to
Old Sep 19, 2005
newkid79's Avatar
newkid79 is an unknown quantity at this point
hey all...im an electronics newb and ive tried looking at the wiring chart and im still confused...
i pulled out my accessory plug and im gonna connect my remote wire to there...there are 2 wires that connect to the adapter...
one yellow and the other/black and silver...
which one do i tap in the remote wire to?
need help asap...
thanks
Old Sep 19, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Ummm neither...
1. If you don't know this, you shouldn't be doing it
2. Even though it's your first post, search before you post.
3. Connect it to the remote turn-on out of the head unit, it's blue. Some head units have blue and blue/white.. one is power antenna and the other is remote turn-on check your manual to see which one is what.
Old Sep 19, 2005
jay78's Avatar
jay78 is on a distinguished road
are u installing amp ??
or hu???
if u installing amp then do wat darklegacy
and
if u just changing hu from stock to aftermarket u dont hve too do anything with remote wire.....
Old Sep 19, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
u connect the remote wire to the search button
Old Sep 19, 2005
newkid79's Avatar
i've searched thanks...
i was connecting an amp...im using the stock HU...so i need a remote wire to turn on the amp...
Old Sep 19, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
why buy a cheap HU it will sound 10x better
you need the power antenna wire... i know our car doesnt have an power antenna butits the wire you need... i just dont know the color
Old Sep 19, 2005
jay78's Avatar
well if u gone use the stok...hu then u need to do this
under the steraing.....their is fuse box look for brown 7.5 fuse "radio" u need tag the remote wire and stick the fuse back in....u done..u can put swich in the middel if u want...thant all u need to do....
Old Sep 19, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
There are a few places that you can tap for a remote wire using the stock deck. The ignition wire (which is switched, meaning it only has power wehn the car is running). The cig lighter wire, especially in this particular vehicle, is probably the easiest place though. Do you own a DMM (digital multi-meter)? If so, simply turn the vehicle off and test the wires. One will be constant 12v source, and one will give you no readout. Turn teh ignition to the on position (don't even have to crank the car). Now retest, the one that didn't have power before should have power now. That lets you know that it's a remote turn-on lead, and that it'll only supply power when the vehicle is on (or at least the key turned to the on position). That is where you can tap your remote. Make sure wherever you tap only comes on when the vehicle is on.
Also, this has been covered, but I didn't want to be a **** and say "search". However, try different terms, such as "remote tap" "stock headunit remote" something like that. Results should come up. Broaden your search terms and most of the time you'll find the answer on here. Good luck.
Old Sep 19, 2005
Ed's Avatar
Ed
Also, you'll want to avoid using the antenna wire. That'll work when you're listening to the radio, but the amp might turn off if you switch to CD or Tape [whatever you're HU is].
Old Sep 21, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
Old Sep 21, 2005
MegaHurtz's Avatar
first search
then post
else lock
Dmitri
123
Oct 13, 2005 08:01 PM
stpfrancois
Jan 19, 2002 08:53 PM
xHoteKx
Jan 8, 2002 09:15 PM
blackbullet
Dec 1, 2001 03:44 PM
Jhonda
Nov 9, 2001 09:48 PM
