will a 240watt amp power 2 10s well?
Old Feb 3, 2002
wishihadavtec's Avatar
wishihadavtec is an unknown quantity at this point
i got this alpine 4 channel 240wattsX1 so it would be 120 watts(4 ohms) to each sub. im not looking for a teribly powerful bass, i just want something that sounds and looks fairly well. the reason its 2 10s is because i already have the box, the subs, and the amp, so let me know your opinions
thanks
Old Feb 3, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
I dun think that it will hit as hard as u want it to be........
because you have a 4 channel amp, mainly it's used to power high's
Which are 6x9's and tweeters and 5x6's.............
I would recommend getting a nice 300 watt 2 channel amp if you want good decent bass
with minimal wattage
Old Feb 3, 2002
VNlilMAN's Avatar
The Standard One
whats the RMS at 4 ohm rating on them? my amp is 80 x 2 RMS n its loud enough for my friends but not loud enough for me
Old Feb 3, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
it'll hit hard enough if you're going for bandpass, but i think you'd need more for open subs.
Old Feb 5, 2002
Marker02's Avatar
Marker02 is an unknown quantity at this point
I have 2 12" Pioneer 500watt subs and i have know idea what kind of amp i should get to get them pounding. any sugestions? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 5, 2002
civic2k2lx's Avatar
civic2k2lx is an unknown quantity at this point
if you want it for your subs, try to get a class D amp,
the 4 channel amp u got now will only run at about 50% efficency
a class D amp will run at 75% efficecy
meaning that:
if u have a class AB amp, that is rated at 300w peak power, and a class D amp, like a jbl 300.1 which is rated at 300 peak power
the class AB amp will only put up 50% of 300w which is 150w
the class D amp will put up 75% of 300w which is 225w
get my point?
so if you only want to use it for subs, they get a mono amp or a class D amp, same thing
EDIT: class D/mono amps will ONLY work for frequencies under something like 80hrz, basically only subs
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Dave1984
Jul 22, 2015 06:10 PM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
