Sound Balance problem SOLVED!!! (Thanks guys!)
Old Sep 7, 2005
Pitch_BlacK's Avatar
Pitch_BlacK is an unknown quantity at this point
Hey guys I already fixed my gain settings now I'm having problem with my sound balance. When I have the head unit balance to 0 (center) the sound of front and rear doesn't sound good and I lose my bass but If I turn both (front left and rear left) all the way to the left it sounds good with bass. Same as to turning the balance all to the right front and rear right sounds good. Anyone knows what seems to be the problem? Need help with it. Thanks in advance.
Old Sep 8, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
sounds like a phase issue. Try swapping the positive and negatives of the left or right side of your car. It sounds like when one side of your car's speakers are pushing out, the other side is pulling in. When that happens, output is severly diminished. Its easiest to notice in the lower spectrum of music
Old Sep 8, 2005
Here is the speaker output from my amp. So I need to swap the negative and positive from the right with the left ones?
Old Sep 8, 2005
MegaHurtz's Avatar
no switch the positive and negative for the right speaker and if it doesnt help, switch them back and do the same for the left. do that for one channel at a time and see if it helps.
Old Sep 8, 2005
Woohoo I just got it working just a few minutes ago and I am so freakin' happy. Finally heard the great sound of my speakers. Thank you very much to all your help guys. I have been frustrated about this problem I had since last week but today was my day!!!! Yay.
ywgflyer
May 15, 2015 05:05 PM
bo_red
Transmission
May 3, 2015 09:14 PM
dennis123
May 3, 2015 03:14 PM
tylerginevan
Apr 27, 2015 12:29 PM
wsking77
Aug 29, 2001 05:34 PM
