Will i blow my subs...
Old Sep 6, 2005
kornsined's Avatar
ok i got 2 alpine 4 ohm type r subs which are rated at 300rms each. the amp i'm looking at is gonna give them 450rms each. am i risking damaging the subs by overpowering them with proper gain settings? my pioneer deck has 2v preouts so if i set the gain to 5v should i be fine playing the deck at high volumes?
Old Sep 6, 2005
AlienX's Avatar
AlienX will become famous soon enough
you should be fine, best way to really find out and set everything to be perfect ( no clipping/distortion, and not blowing them ) is to set everything up on a oscilloscope first to set the gain, then just turn down the sub volume with deck controls ( if possible ) thats the proper way of doing thing.
Simple/risky way: hook it up, set volume to 80%, set gain on amp to the point right before you hear the subs distorting. (This with sub vol being 100%)
Im running 420rms to 300rms subs and NPs. Its not power per say that blows the subs, its clipping/distortion that will kill them. Over powering is sometimes a good thing with some amps because it will let you reach higher db without picking up a lot of noise ( which ALL amps will do as you keep kicking up the power ) noise being a very bad thing..
raymondxcho
Sep 29, 2015 09:00 PM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
jeffsasse
Sep 25, 2015 10:08 AM
Hollywoodsnake
Sep 20, 2015 12:58 PM
