pioneer AVG-VDP1 any 1 hve this ?
Old Aug 18, 2005
jay78's Avatar
jay78 is on a distinguished road
i have pioneer AVH-P5700 and i wants to add this AVG-VDP1 also known as
Dynamics Processor
any one have this instald....how hard is it......is it worthed....?
i found some cool shots chek it out
http://www.autowereld.com/imagesDB/6...505848_pio.jpg
http://www.autowereld.com/imagesDB/6...053169_pio.jpg
http://www.autowereld.com/imagesDB/6...044130_pio.jpg
http://www.autowereld.com/imagesDB/6...504067_pio.jpg
http://www.autowereld.com/imagesDB/6...504992_pio.jpg
and the best one
http://www.avbuzz.com/audio-video/200507/pioneer-n/
Old Aug 18, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I just installed one a few weeks ago in an RSX Type S.. a lot of work.. I guess it's worth the money though. I think it's cool how it gives you real time analysis. I suppose it's a toss up.. if you've installed a navigation system before, this is about the same general idea as far as installation goes.
Old Aug 18, 2005
jay78's Avatar
i naver done nevi....
where can i find diy for this......
if u hve pic and where did u place that unit?
shop want 60 to 70 to install......is it good....price....
Old Aug 18, 2005
Wow, that's not a bad price at all for installation. Our shop would probably charge $100-$150.. well, probably less if you bought it from us too I suppose.. ehh
I don't have the unit, but I installed one in an rsx at work. it's not really too horrible I suppose. Just a lot of work.. it involves splicing into your reverse sense, speed sense, and other misc things like that. Nothing hard, just time consuming finding all the wires and running them while keep a clean look. In the rsx, I put the unit underneath the driver's seat.. luckily there was enough room there for all the wires and the unit and still maintain operation of the seat to go forward, backward, up and down without hitting any wires or anything. one of the main issues with that specific brain box, is that it must be mounted on a flat surface so you can't just dump it in a panel or under the steering column and it has to be mounted parallel with the car as well.. just a bunch of little happy horse $hit things like that
Old Aug 18, 2005
jay78's Avatar
i should get my unit next week.....post some pic when it done
is their any diy on any site meybe??????
Old Aug 18, 2005
No idea? lol search for one I suppose.. I doubt there will be though, it's too new.
Old Aug 18, 2005
jay78's Avatar
add some links on 1st post
Old Aug 18, 2005
es2k2's Avatar
Proud to be a civic owner
very nice....
n1 and n2 doesn't have it right???
Old Aug 18, 2005
jay78's Avatar
same unit works on n1 and n2 aswell
Old Aug 19, 2005
That's correct.. it uses they all use the same plugs for xm radio and cd changers.
Old Aug 25, 2005
jay78's Avatar
i just got my unit today in fedex.....will be intalling in today......installation....seems to easy then wat i thought......only hard part is the finding speed wire....here some pic
Old Aug 25, 2005
The vehicle speed sense wire is white with a green stripe located at the PCM.. which is behind the glovebox in connector A, pin 18. The speed sense wire is also blue with a white stripe at the cruise control module which is located at the left of the steering column.
Nothing difficult, just time consuming.. always test your wires first..
Good luck!
Old Aug 25, 2005
jay78's Avatar
well done working fine....will post some pic when its done......i like it
Old Aug 25, 2005
jay78's Avatar
working but qustion
that green wire i hooked up to ebreak.....
now some of the future i can't use while drving like cange colors vechiel....stuff like that only can when my ebreak is up, is their any way i can use this future while i am driving ??????like hook up a swich like for dvd player.....
Old Aug 25, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
yes you can but its easier to lift the e-brake just enough until the indicator lights up on the dash then you can adjust everything. on our cars i dont know why anyone installs switches vs. putting a hackysack under the e-brake handle
Old Aug 25, 2005
jay78's Avatar
when i lift the E brake littlebit.....just enought to get the light up...i will be able to probllly dind't try ....but that wont slow my car.....???? does it relly using my ebrake???
Old Aug 25, 2005
nick95673's Avatar
if you take you center console off you will see a pin switch near your e-brake. that pin switch is what tells your hu and dash that the e-brake is engaged. and no it wont slow your car down if you lift it just enough to get the light to come on.
Old Aug 25, 2005
jay78's Avatar
for my hu i had to put a toggle swicth to watch dvd while draving......grounding ebrake didnt working........sence this avg-vdp...show location...rmp hp all that stuff on screen......now this unit also got saprate ebrake wire....now if i just same thing that i did for my hu....will it show rpm..gps...that stuff? ????
Old Aug 25, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
5700 you have to do a toggle switch to trick to get to bypass ebrake. you just can't ground the green wire.
Old Aug 25, 2005
jay78's Avatar
kiker i did that alrady for my dvd and it works......but how about the avg-vdp1 it also have that wire....it has gps...system....so if i do that will my gps would work ???
Old Aug 25, 2005
It doesn't have GPS.
Old Aug 25, 2005
jay78's Avatar
well it tells you where u are and it tell u where to turn and ****...tho..u can also save location....then u just tuch return home....stuff like that
Old Aug 25, 2005
diskreet's Avatar
most likely the 1st notch on the e-brake is doing NOTHING but making the pads go closer to the drums. i should say don't do it but unless someone actually knows it will cause harm i doubt you will hurt anything
Old Aug 25, 2005
jay78's Avatar
i am gone try that asa i get off from work....and see wat happns.....let u know...tomo..also will try get some pics.....
Old Aug 26, 2005
nick95673's Avatar
you shouldnt even need to pull it up a notch. my light comes on even if is only 1/2 inch up
Old Aug 26, 2005
jay78's Avatar
well i did it but it enable the options only for sec or 2 then disable even my ebrake is up.....cuz it sees that car is moving or somthing i dont wat to next now
here some pics
Old Aug 26, 2005
es2k2's Avatar
wow.. very nice...
Old Aug 26, 2005
vietstylez's Avatar
damn.. what pioneer units is that compatible with?
Old Aug 26, 2005
jay78's Avatar
i am using pioneer avh-p5700....any pioneer with tuchscreen...and navi input should work with...
pics didnt come out good...will post better one later...
Old Aug 26, 2005
jay78's Avatar
new pics added
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
