Sealing a subwoofer box without permanently sealing it.
Old Aug 18, 2005
Seabass's Avatar
Seabass is an unknown quantity at this point
Hey everyone, ok im making a subwoofer box and I need to seal it but want to make it so that if I need to take a certain part of the box off then I will still be able to. Is there anything out there that will allow me to do this? Thanks everyone.
Old Aug 18, 2005
2002excpe's Avatar
Have you seen Mike Hunt?
2002excpe will become famous soon enough
Ibtm
Old Aug 18, 2005
2004_sq_champ's Avatar
2004_sq_champ is an unknown quantity at this point
Why would u need to take off a certain part of the box?
Old Aug 18, 2005
Seabass's Avatar
Because the box takes up the whole trunk and can only go in when assembled in the car, so when I need to take it out for some reason I need to take the box apart inside the car first.
Old Aug 18, 2005
just build a box that fits.
Old Aug 18, 2005
Seabass's Avatar
Box is already built, plus this gives me much more room.
Anyone know if there is such a prodcut? thanks.
Old Aug 18, 2005
You said it takes up the whole trunk, so how can u have more room this way?
Old Aug 18, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
I think he means accross or sideways it takes up the whole thing but not the entire trunk. Like it goes end to end at the back of his trunk (right behind the seats) but then he has the rest of the space 4 his clubs or whatever.....
If he didnt mean that^ then he doenst make sense.
And I dont think that their is such a thing. The only thing that I could think of is build a boxk that fits and then add sides to it so it's flush mounted but that would be depriving u of air space and it sounds like u need alot of it.
Old Aug 18, 2005
WhiteRabbit's Avatar
depends whether or not the break is at a joint (like a removable baffle) or in the middle of a panel.
if its a baffle, screws and weatherstripping. if its a once or twice ever thing, or once a year removal, then id use strip caulk.
if its the middle of a panel where you make yout cut, then coffin locks and weatherstripping. ideally, the locks would be on the inside of the box, you can lock together the box, then install the woofers.
its a little ugly, but you can just put coffin locks on the outside if you want.
Old Aug 18, 2005
tko's Avatar
tko
tko is an unknown quantity at this point
if the screws are accessible, y wouldnt that be simple enough?, anything else with caulk and glues would be messy with reheating and what not
TKO
Old Aug 19, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Do you own a razor blade? If so, you can simply use silicone caulk. You'd have to remove it once you took the piece out, but that's not too hard, just spray a thin layer of gloss spray paint on the places the caulk will contact. It'll peel right off when you're ready.
Old Aug 19, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
although I know what you're talking about... if it wasn't in text format, that would sound painful.
Old Aug 20, 2005
Seabass's Avatar
box takes up "most" of the trunk, enough space left to put maybe a tiny little bag....actually I take that back, after the amps are mounted there is no room at all. I also have a 5 gallon air tank in there.
Old Aug 21, 2005
k20txem2's Avatar
k20txem2 is an unknown quantity at this point
picture? so we can see what you want to do?
pheaton
May 4, 2015 08:26 PM
WLakers
May 4, 2015 06:23 PM
jstotts
Apr 20, 2015 09:32 PM
AlexLx
Nov 7, 2001 10:09 PM
