gauge pod and tweeter?
Old Aug 18, 2005
Will adding a single pillar pod with gauge cause any problem with me hearing the tweeter? I'm thinkin maybe since the tweets are already angled towards the dash? Any idea?
Old Aug 18, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
where are your tweeters located? Are they in the sail panel or something? Any thing you put in your car anywhere will probably have an impact on sound but it probably won't be noticable to your ear.
Unless the pillar pod is in the way of the sound waves I wouldn't worry about it. If it is you may be able to adjust your eq, time delay or whatever else you have to play with to compensate.
Old Aug 18, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
from the how you described the issue no it wont cause any problem
Old Aug 19, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Shouldnt' unless it would be litterally right in front of the sound path. Do you have a pic of the setup any chance?
Old Aug 19, 2005
no the pod isn't here yet. I'll take pics later. the tweeter is in the sedan sail panel and pointed towards the front rather than my ear. I can still hear it fine, but worried that with the pod right in front, it won't sound as loud.
Old Aug 19, 2005
J187's Avatar
OH, meaning it would block it after it reflects off the glass, right? Seeing how the tweeter would be closer to you than the pod? I wouldn't worry about that at all. If anything, to satisfy your curiousity, you could simply hold an object in place where the pod would go, like a cup or something, and listen to it. . .
Old Aug 19, 2005
um no. i should just post pics later. the pod is right in front of the tweeter.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
ZoSoIV
Sep 17, 2015 07:17 PM
