Subwoofer installing question
Old Aug 15, 2005
Ruamit03's Avatar
Ruamit03 is an unknown quantity at this point
Hi guys,
I was wondering is it possible to install a subwoofer and a amp with the stock head unit still in there. Yea i know why leave the stock head unit, well first i m getting a killer deal on the amp and sub and also I have like a 7year 100k warranty on the car and I don't want to Void that. So what do you guys think. Thanks in advance for the help.
Old Aug 15, 2005
2k4civic2101's Avatar
2k4civic2101 is an unknown quantity at this point
yes, you will need a low level line converter that can be found at pretty much any audio store ... you will connect your amp normally (ie: power, ground, remote wire...) ... the line converter will then tap into your rear speaker wires and give you an rca output to run to your amp. As far as the remote wire, you just need a 12v accessory wire, plenty of options.
Old Aug 16, 2005
jay78's Avatar
jay78 is on a distinguished road
i use hve that way...but it relly didnt sound that good....so i took my stock one out...if u relly about sound then u wont like it.. u can try convert only cost $ 15-20
Old Aug 16, 2005
MegaHurtz's Avatar
installing deck will void no warranty
Old Aug 16, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
U will not void ur warrenty with a HU change. They dont care if u change ur cd player to an aftermarket one. The only thing that can void the warrenty r things like getting lowered/engine mods like turbo,cams, etc.
Line out converter = $15-20 and 4 the remote wire you could use the blue or blue w/ white stripe from ur HU wiring harness or # 15 fuse in the car.
Old Aug 16, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
new HU wont mess with warrenty unless you really mess up wiring it in (almost impossible)
Old Aug 16, 2005
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
^^^ You'd be suprised what I have been through before. I had an amp and HU installed about 3 years ago and I had a check engine light come on right after it was done. Took it into the dealership and they told me some BS about how the Amp caused the PCM to fry and it was going to cost $700 to replace. I was like WTF and took it to another Dealer, they swapped out no questions asked.
masongap
May 26, 2015 07:55 PM
WLakers
May 4, 2015 06:23 PM
pincookie1
May 4, 2015 12:22 PM
