crackling sound from speaker
sup everyone?? i noticed last night that when i drive over a bump or turn, basically when the car moves, or especially when i tap the top of the dash my stock radio emits a crakling sound from the front driver side speaker. when the radio is off the crackling sound is not there even if i tap the top of the dash
does anyone have any suggestions or solutions for this? should i open the front door panel and dash or radio and look for a loose wire? oh the fuse for the radio is fine i checked it and it looks fine, i also replaced it just incase.....help.....anyone.....thanks
does anyone have any suggestions or solutions for this? should i open the front door panel and dash or radio and look for a loose wire? oh the fuse for the radio is fine i checked it and it looks fine, i also replaced it just incase.....help.....anyone.....thanks i got almost the same problem but i got a pioneer radio and when im driving listening to my cd everything is good but once and a while the left side would fade out and the right side would only play then it will come on later but when i put on the radio this problem never happens can anyone help me out too
check behind the radio for a loose wire. tug on the connections (not TOO hard but hard enough to pull out a wire if it was loose) and see if any of them come apart. I am assuming you have an aftermarket deck, is that correct?
"gearbox" i tried searching for door panel removal for a sedan, but came up empty..can u help....thanks....oh, to answer your question "pg" im still running on the stock radio.
I have a similar situation in which the music will crackle and start to fade out and in a matter if seconds the music fades from the speakers and only the subs r left playing... It must be a loose wire I cant think of anything else that it would b but I just havnt taken the time to try and fix it. Alpine HU and amped the speakers which r diamond audio.
i know my tweeters sometimes cut off completely but pulling out the deck and jiggling wires fixes it lol.
here's door panel diy
http://www.7thgencivic.com/forums/sh...d.php?t=149120
Wanna see a donkey show?
SAme here it happens to mine in the rear same spot. Only over bumps and such. And is real on and off. This did not occur until I had the tinter change the rear deck speakers and yes my deck is after market. I will check the connections but like I say its real on and off.
carid
Aug 8, 2015 05:05 PM
Nalmonte
Jul 22, 2015 09:08 AM
