2 Alternators Dead from Audio?
Old Aug 9, 2005
UltimateWarrior's Avatar
Pimp My Ride!! Please!
UltimateWarrior is an unknown quantity at this point
Hey all, I went through a bunch of crap recently and I think my audio upgrades caused all this although I can't prove it. I've been through two (2) Alternators, a battery, a fuse box, and all sorts of diagnostics over the last six months from a local machanic trying to figure out why my car kept dying! What a hassle!
Has anyone else ever had issues with Alternators with a nice system? I mean, tons of people have nice systems in their cars and never have issues! Why me??
I HAD two (2) 12" Pioneer Premere Subs and a 1600Watt 4-channel Amp using a 4 guage power wire from the battery. Two of the channels on my amp went to my Subs (bridged) and the other two for the front speakers. It all worked fine for about six months then my car started to act goofy. That's when all the problems surfaced and I've been through a lot of expense lately. I tore out all my audio and said "That's it!" I'm done with upgrades unless someone can tell me how I can run a good system in my Civic without destroying my car, especially my Alternator! I am not going through this again.
If you haven't experienced any issues yet then you have been lucky I guess, or have a better setup than I had. I just don't think my battery (stock) and Alternator could handle the draw.
Any ideas what I can do so I won't fry stuff again? I'd hate to sell my Subs because they are awesome and I miss my audio.
Old Aug 9, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
i dont think it was the adio if you burnt throught two Alts.. i think its a bad ground from the alt or a bad belt/pully connected to the alt
then again i know crap when it comes to ICE
it may be you Amp with a bad ground for all i know
Old Aug 9, 2005
Yea, hard to really say but my amp's ground did work loose one time and come to think of it, I wonder if that started the whole thing? All it did at first was shut down my amp but when I reattached everything it all worked fine. I can't remember if the first Alternator went after that or not. Hmmmm... It could have caused something to go flaky, like a sensor or something. I was getting ELD sensor problems which they had to replace my fusebox! A new battery, and now I am on my third Alternator.
I am paranoid to hook anything up again to my battery as you can imagine.
Old Aug 10, 2005
streetglower's Avatar
first thing I would suggest is replace your battery with a optima yellow or a heavier duty battery. Also possibly upgrade your alternator to see if that cures the problem. it justs seems like that is the main problem. Too much audio for the stock components to handle.
Also, try taking your car to an good car audio shop and see what they say. My last job would always send cars to a local car audio shop when cars came in with problems due to there system. they did bad *** work. or try taking it to a shop that deals only with car electrical issues. there should be one in your area. And you shouldnt be spending any more money then what you have. If the shop tells you whats wrong, fixes it and charges you, and it doesnt fix the problem, you shouldnt have to keep paying for them to start throwing parts at it.
Old Aug 10, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
yeah definatly try upgrading you alternator to one that has a higher amperage rating.
Old Aug 10, 2005
And what kind fits our cars and how much??
Old Aug 20, 2005
kumanan's Avatar
kumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the rough
bump?
Old Aug 20, 2005
what kind of system are you running to burn out alternators? Alot of people here have some 1000wrms+ on the stock electrical system. HO alternaotr is usually a bad idea because it robs more hp than normal. You shouldn't even need to do that. I had 2 subs and two amps for about a year at least and I was fine. Yea mine broke too after 3 years, but prolly just a random failure.
Old Aug 20, 2005
MegaHurtz's Avatar
I would say its almost certainly not your system causing the problem... that's really a lot of power and shouldnt be enough to ruin your alt... look elsewhere...
Old Aug 20, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Normally, I'd say it's the alternator.. I burned up my stock alternator, had it rebuilt to 90 amps, burned that one up.. now I have an Ohio Generator which I've had for quite some time now and no problems.
But since you said you went through your fuse box among other things, I think you have another electrical issue with your car.
Old Aug 20, 2005
MegaHurtz's Avatar
why did you replace the fuse box anyways?
Old Aug 20, 2005
They replaced the fuse box because the ELD sensor was faulty they claimed. You don't have to replace the whole fuse box I found out but they were able to get one out of another car for the same price as just replacing the ELD sensor. So I don't know if my alternator caused other issues or what. Now I currently have my third alternator in there and so far it's ok but I do not have any audio hooked up. I do not want to chance putting any draw on my battery or alternator again. I can't afford to keep having it in the shop. I am going back to just my radio hooked up to four speakers, front and rears, no amp or sub. Not worth all the hassles.
Old Aug 20, 2005
the ac and windows takes more power than the stereo, if you keep it relatively stock. An aftermarket deck and small speaker amp wouldn't hurt it. And even if you have a big system and the alt can't supply power, it then takes it from the battery. Eventually the battery would drain, but I can't see how the alternator would be affected by that.
Old Aug 20, 2005
Yea, plenty of people have nice systems and I just can't understand why I had so much bad luck about six months after installing all mine. I did everything right and the only thing I can think of is my ground from my amp (bolted through the trunk body) worked its way loose one time (from the terminator) and this might have caused some faults in my ELD or screwed up my alternator, who knows.
I really miss my audio and I drive around all day long for my job so it's real difficult not even having a radio at the moment but I am so paranoid to hook anything up from my battery again. Maybe my current amp just isn't any good or draws too much power. It's a 1600 Watt, four channel Legacy. Not the best amp in the world by all means but again, it did just fine for six months until things started acting goofy with my car.
My friend has a nice system too and he even has a cap and his alternator just went last week also. He drives an American made car. I think over time the drains on the battery and alternator just takes it's toll, who knows.
I may go to one of these custom car shops in my area and see what they say. I think I need some expert advice on all this. I am not happy with my current system anyway. I have a nice head unit and the subs are awesome but there is no mid-range. My little Panasonic fronts are crap. I need four speakers and maybe just one 10" sub. That would do me just fine. I will get a quote on them installing everything and maybe get some type of warranty that way, who knows. I just don't trust myself anymore.
I'm sure I can find a place to connect all my gear and do it right if I purchased all the stuff.
Old Aug 20, 2005
this is just a guess, but maybe if the stereo is using the battery all the time, the alternator is constantly working to replenish it and eventually burns itself out. thats kinda what the mechanic said when my alt went out with the aem underdrive pulley on it. so now i'm using stock pulley. but its all guesses. also fyi, the eld turns the alt off at times when its not needed. the eld DOES NOT see the stereo system because of the way its wired.
Old Oct 5, 2005
Jamil2005's Avatar
Jamil2005 is an unknown quantity at this point
hey everyone i'm new to this so I apalogize for my obvious lack of knowledge. Ok but i went to get a deck i baught a while ago installed into my new 2004 civic, and apparently because the deck has a high amp rating it was taking too much power and fried my whole electrical system and cost me 2 grand. Does anyone have an idea how that happened or how to get a deck to work?
Old Oct 5, 2005
How many amps was your deck rated at? I never heard of a head unit causing too much draw but I'm no expert either. Usually your amp and big subs are what causes the drains I heard.
Sorry to hear about your 2 grand loss. I know the feeling. This car has cost me thousands! Between the audio mishaps and now my transmission, I think this is the worse car I ever owned.... seriously.
Old Oct 5, 2005
jay78's Avatar
jay78 is on a distinguished road
gearbox... i have stock alt and bat. i am running 1600rms amp and 60x4 rms 1frd cap....i hve aem power pulley u think i will hve same problem ?
i am think about to change uthodox crank pulley?? would that make any diff ?
Old Oct 5, 2005
damn you're gonna have serious problems. aem doesn't even recommend running any system with the pulley. My mechanic was 99% sure the pulley didi it, and I didn't even have a big system. Give it a year, and you'll be walking home one day. Crank pulley will ruin your engine.
Old Oct 5, 2005
jay78's Avatar
holly s*it.....spend 250 to get them installd now pay 250.00 get them off....damn...
150. parts....and 175.00 crank pulley panding....
and how about if put better battery,Alt and keep aem pulleys...would be a problem then??
Old Oct 5, 2005
ya the pulley causes the alternator to work non stop to charge the battery (because the pulley will underdrive it. He said it just burned up eventually. Leave the PS pulley on, just put the stock alternator back. Bigger battery won't help that much. I had single amp 25wx4 and it still died.
Old Oct 5, 2005
jay78's Avatar
alright when i put my bigger alt i wont put that aem alt pulley....i should get it with week or 2...
Old Oct 5, 2005
cool
Old Oct 5, 2005
LOL, you guys are a trip. I'm done messing around with my car. It's not worth the cost and aggravation anymore. If I had it to do all over, I would have kept everything stock, including audio. But no, I had to find this site and I got hooked. It's funny when we look back on life and all the silly things we do.
Have fun gang. It's only money right?
Old Oct 6, 2005
Yea, I think I realized I got a lemon early on but it's like one of those love-hate relationships. I keep spending money on an old hag but can't affort anything else at the moment. LOL
Old Oct 26, 2005
K20A_Wanabe's Avatar
K20A_Wanabe is an unknown quantity at this point
what is the factory alternator wattage output?
Old Oct 26, 2005
PunkingCivic's Avatar
I need TP for my bunghole
is anyone using a compacitor(s) with their system and have had this issue.
Old Oct 26, 2005
MegaHurtz's Avatar
this thread is long since dead. if you have new questions please make a new post as per the rules posted in this forum.
Skunkone
Sep 24, 2015 04:38 PM
JMKendrick
Sep 16, 2015 06:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
Bricoleur
Sep 9, 2015 12:30 PM
Bricoleur
Sep 9, 2015 12:23 PM
