deck, fuse, or other?
Old Jul 27, 2005
gh0st's Avatar
TAQUITOS!!!!
Unhappy deck, fuse, or other?
so i tried to fix my pioneer 8500mp with the kit off ebay and now, when i tried to hook everything back up the deck doesn't turn on
i was thinking it was the 7.5A radio fuse under the steering column and i took it out and it was broken...so i changed it with another 7.5 one and i tried again, but no luck...
i don't remember pulling anything out of the deck and i put it back together..correctly i think. so now my deck doesn't come on whatsoever and now the cd my cousin got for my is stuck in there....
so what's my next thing to check guys? any ideas?
Old Jul 27, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
By any chance is the Fuse blown again?? Maybe you are grounding somewhere and the fuse is blowing as soon as the deck is turned on (or attempted)!! Just a thought!!
Old Jul 27, 2005
k20txem2's Avatar
k20txem2 is an unknown quantity at this point
Hopefully you dont have wires crossed
Old Jul 27, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
yea, check wires..
Old Jul 27, 2005
MegaHurtz's Avatar
backup fuse under the hood
Old Jul 27, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
does the factory deck work? if it does then its probably your new deck. if the oem works take the pioneer twist the yellow and red together and put a 10amp fuse in a line and put the yellow/red to positive and black to ground on the battery. if it still doesnt work then bad deck. if it does work check your fuses.
Old Jul 27, 2005
gh0st's Avatar
TAQUITOS!!!!
i double checked the fuses....which backup fuse under the hood?
i tried plugging the oem one in, but that one didn't turn on either, i'm not sure if i changed the fuse out yet when i plugged the oem one in...let me try that again.
i've been running this deck for nearly 2 years, but just took it out recently to try and fix it. i never took out any of the wires
Old Jul 27, 2005
nick95673's Avatar
pop the hood on the pass side on the wheel well theres a black plastic fuse box. the diagram is in the manual. most likely this is what you blew
Old Jul 27, 2005
gh0st's Avatar
TAQUITOS!!!!
i checked those...there's nothing specific to the radio...so i didn't really pull any out...or did you mean the one that read "back-up fuse"
Old Jul 27, 2005
nick95673's Avatar
check all of the fuses. your electrical system is like a tree. theres the battery whis is the trunk then theres a general electronics back up fuse which is a branch. then theres the radio fuse witch is a twig, finally the fuse on the back of the radio the leaf. if any are blown even if they are not labelled radio will stop your radio
Old Jul 27, 2005
gh0st's Avatar
TAQUITOS!!!!
sweet, it was the "back-up" fuse.
to you all. thanks guys, it's been bugging me
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
General DIY
Sep 25, 2015 08:02 PM
h4ldol
Sep 17, 2015 01:25 PM
jpat21
Sep 3, 2015 11:32 PM
