Console Assembly (Around the Radio)?
Old Jul 16, 2005
nawaf88's Avatar
nawaf88 is an unknown quantity at this point
does that piece thats around the radio and around the controls for the A/C and heater come off without having to take apart everything from around the gear shifter and up. Does it pop out or is it held by screws or something.
Old Jul 16, 2005
Overboost's Avatar
Overboost is an unknown quantity at this point
pops out, just gotta mess with it by slowly pulling from the top then working it around the sides, it's held on by clips. Don't worry about putting some umph into it b/c if the clips pop off you can just pop them back on.
Old Jul 16, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Ummm no it doesn't there is a screw underneath... You're going to mess up the dash quite a bit if you try just pulling it out. The ac controls are screw'd on to it, then the wires are plug into those. Thos wires are pretty short, so they also hold it in. The only way is to take the whole center dash out.
Don't listen to people who tell you it pops right out, they prob never took it apart. Its much easier removing it the right way.
Old Jul 16, 2005
nawaf88's Avatar
thanks Blahman. I didnt think it was that easy either.
Old Jul 18, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
definitely, you gotta take the center column (shifter/pocket/ebrake thing) apart to get at the "secruity screws" (used so theives cannot just rip it out even with force) 2 screws that holds the center peice in place.
You dont have to put those two screws back if you plan to take that center peice out alot. The clips hold it in place just fine. AND Im pretty sure everyone here that does screen mods and stuff doesn't have those two "security screws back" in.
Old Jul 18, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
01-03, remove the little pocket at the bottom and remove the screws (there are two originally, some people only put one back when they reinstall it).
04+- it's all gotta come out.
There is a DIY on here for both.
Old Jul 18, 2005
Bigfella's Avatar
Bigfella is an unknown quantity at this point
Not been funny guys, but half the explanations above are incorrect, couple are accurate though.
Remove ashtray
There is a screw behind the ashtray, remove this.
If you can feel with your hand or see up above the ashtray there is one screw to undo, thought there would be two, not sure if one missing?? Any way this holds all the metal-work that is attached to the plastic piece that we are removing.
Carefully start at the top and gently pull it away from the dash, then undo five plugs, three heating, one hazard and one ashtray and thats it.
Old Jul 18, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
hrmm...mine pops in and out really easily. i can take it off while i drive lol. i know because i used to have to reset my power coverter sometimes and its behind that piece. i just pop it out by pulling on the top. done it tons of times and it isn't loose at all.
Old Jul 18, 2005
stinkypie's Avatar
A big, hairy Kentucky boy
stinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to all
We need more information on the car(year? trim level? etc)
Old Jul 19, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
Your answer is in the DIY.
Here's the link to the DIY
http://www.7thgencivic.com/forums/fo...play.php?f=110
There are 2 different write ups on how to install a HU, so it depends on the year of your car. Just a take look at both. Which ever looks closest to your interior, follow that one.
h4ldol
Apr 24, 2017 08:16 PM
ricer_em2
May 11, 2016 08:09 PM
Mc7602
Sep 17, 2015 02:01 PM
jpat21
Sep 3, 2015 11:32 PM
