Installing aftermarket head unit in 03 Civic Sedan
Old Jul 12, 2005
03CivicSedan's Avatar
03CivicSedan is an unknown quantity at this point
I'm not sure if this will help anyone, but I'll tell you how to do this because it was kind of a pain to figure out. Sorry no pics, dial up sukks
First remove the panel that your cigarette lighter is hooked to.There's a couple of little clips on it just start from the back on the side of the shifter and work your way forward.
Next just undo the two bolts that's in the whole where you removed the cigarette lighter from, they are on the overhead and are 8mm.
After that just carefully pop the front panel that the head unit and the A/C controls are on. The clips are mainly in the corners and 1 or 2 clips in the middle.
I'm not sure if this has already been posted, but I didn't see it anywhere. If someone did I didn't mean to step on toes.
I also hear that some people complained of there dome light and the keyless entry going out when the stock radio was removed. You may want to check the fuse panel under the hood and make sure that the fuse labeled as back-up didn't blow. That fuse is also for the 12v+ on your radio.
Hope this helps
Old Jul 12, 2005
Rennen's Avatar
New Mod on the Block
already in the DIY section. but thanks anyways.
vtec92
May 4, 2017 03:20 AM
mugenca
Apr 16, 2015 12:15 AM
aus10
Apr 13, 2015 09:26 PM
pdxbiker
Nov 7, 2001 10:06 PM
Crash2002
Oct 26, 2001 05:02 PM
