better radio reception?
Old Jul 10, 2005
any way to improve aftermarket radio reception? Its okay but could be better.
Old Jul 10, 2005
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Could get and antenna booster like from wal mart, it helps
Old Jul 10, 2005
hmm thanks I'll check it out.
Old Jul 10, 2005
no prob you could also try radio shack or ebay? I know ive seen them around for like 10 bucks
Old Jul 11, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
when installing your aftermarket HU, did you connect the power antenna from the HU to the power antenna wire from the car harness, because even if we don't have a power antenna that goes up when you turn on your radio, we have a booster somewhere, so you need to connect that wire.
Old Jul 11, 2005
ya i'm sure i did. the reception is decent, just could be better.
Old Jul 11, 2005
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
I'm pretty sure you know what your doing but did you play around with the different FM band modes (FM1 FM2 FM3 etc.)? Also is it a Pioneer deck? Because the tuners on those usually go out after a while.
...Also, you sound like a good canidate for Satellite Radio, Digitial broadcasting coast to coast.
Old Jul 11, 2005
pioneer deck. it sounds like it did the first day. it has reception bars like a cell phone and usually 4/5 are lit. So its good just looking to improve. prolly not a big deal. oh yea i tried xm and hated it. terrible quality and programming, and my tuner broke in 2 weeks anyway.
Old Jul 11, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
not really. we have the stupid window antenna. when i tried every product out there and none help. pioneer and alpine have the best tuners as far as fm goes and they both suck. typically you will not get 1/8 the reception on am with aftermarket that y7ou would get with oem. it sucks but the only thing that worked for me was when i grabbed a conventional car antenna and plugged that in for a minute with it just hanging out the window. i ended up with sirius and havent put a cd in since and have no desire for am fm now. it just makes me upset when i listen to the retarded stuff they edit out i mean whats the diff between "grind on me" "grind with me"?
Old Jul 11, 2005
MegaHurtz's Avatar
double check that you hooked up that wire
Old Jul 11, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Get a civic hybrid antenna and mount it to your roof People are constantly asking if Im playing a CD when I'm listening to FM with my alpine.
Old Jul 11, 2005
more info??
Old Jul 11, 2005
omg almost $100 for all the parts!!
Old Jul 12, 2005
Echelon04's Avatar
The one and only....
Echelon04 is an unknown quantity at this point
it would look golfish
Old Jul 12, 2005
nick95673's Avatar
but its like i said a conventional antenna is the best route
Old Jul 12, 2005
where would I put it tho, would it still get good reception under the floormat?
Old Jul 12, 2005
pr0vidence's Avatar
pr0vidence is an unknown quantity at this point
FYI the booster is hanging off the rear window under the passenger side panel that's just above the rear deck. Found it a few weeks ago while ripping everything apart to replace the stock 6x9's.
At least, that's where it's located on the 05 EX coupe. Can't imagine it's any different for all the others.
Old Jul 12, 2005
nick95673's Avatar
nope you would want it on the outside of the vehicle. thats wht even though i could get the parts for free i just went with sat radio. im sure gearbox mr. ask me about any diy can figure out a way to do it and make it look clean. i would say your best bet for hiding it is between the hood and the windshield wipers
Old Jul 12, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
um i know some of our antennas are in the back corner of our rear windows. you could extend that. if you look into the car from the back you can see when it is set. left or right i forgot.
ricer_em2
May 11, 2016 08:09 PM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
Mc7602
Sep 17, 2015 02:01 PM
jpat21
Sep 3, 2015 11:32 PM
