Mrd 500
Old Jun 27, 2005
JJJ's Avatar
JJJ
JJJ is an unknown quantity at this point
Mrd 500
well after about 1 week after I ordered a pair of 12" type R alpine dual 2 ohm subs Sonic Electronics said that they were on backorder and I wouldn't see it for 3 weeks. I asked them to cancel the order and they did but the guy said that my MRD 500 digital amp is underpowering the 2 12 inch type Rs that I have and I should get a second amp....? I had it for 2 years and I thought they were good but am I really underpowering them....he said they are rated for 500 watt RMS and the amp should only power 1 sub not 2....urgggggh!!!! So do I stick with the 2 subs at dual 2 ohm impedence or just get the one like he said????? I dunno I'm sad!!!
Old Jun 27, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
u r underpowering them but both of them underpowered should still hit harder then just the one because u have twice the airspace being moved with the two. The subs r rated at 300 RMS and they recommend that you power a sub at least 70% of its RMS power and that means that if you had them both hooked up you would be close to that but still... it's ur call man if u wanna get another amp it would really pound..
Old Jun 27, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
300 RMS? My type R's are rated at 500 RMS. I've got that same amp with 1 type R and it sounds great. You could get the mrd 1000
Old Jun 27, 2005
winnerpl's Avatar
winnerpl is an unknown quantity at this point
^^^^ yup. unofficially the type-rs are best at 500-600rms each
SammySC
121
Apr 7, 2017 07:43 PM
Skunkone
Sep 24, 2015 04:38 PM
Stock 99
Sep 5, 2015 06:06 AM
