Advise on Stereo Setup Series or Parallel. Alpine or Eclipse...
Old Jun 19, 2005
Pure's Avatar
Pure is an unknown quantity at this point
Hi everyone,
I want to know if I should use my Eclipse amp to run my whole stereo or should I use my Alpine amps. Also should I run my subs in series or in parallel for best base? What is the best way to wire the subs? If I use the Eclipse amp it only has one channel for a sub.
Amps:
I have and Eclipse EA3532 5 channel Amp.
105W 4 channel Max. Power Output at
2 plus 230W x 2 Max. Sub-Out
60W 4 channel (2 ), 120W x 1 channel (4 ),
0.1% THD Stereo @13.8V
(RMS Continuous Power)
40W 4 channel (4 ), 120W x 1 channel(4 ),
I have Alpine V12 MRV-T707
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 70W x 2 @ 12V
THD at 4-Ohm RMS Power: 0.08%
Bridged RMS Power @ 4 Ohms: 240W x 1 @ 12V
Speaker Level Inputs: No
Preamp Outputs: No
Built-In Crossovers: HP/LP
Bass Boost: 12 dB
Frequency Response: 10-50,000 Hz
Signal to Noise Ratio: 105 dB
I also have a Alpine V12 MRV-F407
RMS Power @ 4 Ohms: 40W x 4 @ 12V
Bridged RMS Power @ 4 Ohms: 100W x 2 @ 12V
Preamp Outputs: Yes
Bass Boost: 12 dB
Speakers:
I have 2 Dual voice coil Kicker Pro 10” Subs, 4ohms each. 300rms
I have 2 6X9 Alpine 250w in the rear
I also have 2 4” Panasonic mids in the front with tweeters.
I have a Alpine 9XXX Head unit Mp3 player.
Thanks,
Pure....
Old Jun 19, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
use the MRV-T707 to power the subs. Are they two dual voice coil subs @ 4 ohms per voice coil? If they are, wire each sub in parrallel for a two ohm load per sub, the connect the two subs in series to the amp for a 4 ohm total load
Old Jun 20, 2005
LayinLo's Avatar
LayinLo is an unknown quantity at this point
And if you don't know what he's talking about, check here for some more info:
Amp and Sub Wiring Guide
Old Jun 20, 2005
MegaHurtz's Avatar
wire the subs to whatever load your amp will handle, there is no "best" way
Old Jun 20, 2005
LayinLo's Avatar
the lower the ohms, the more watts it gives out
SammySC
121
Apr 7, 2017 07:43 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
zeshan7616
Sep 15, 2015 12:24 PM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
krazykoncepts
Sep 8, 2015 09:02 PM
