Shift Light Install...HELP
Old Jun 18, 2005
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
hey guys..where did everyone elts take their tach wire lead from, and what color was it? I was looking in behind my gauge cluster to see if i can steal a signal from there, but those wires are wrapped up nice and tight
any info would be appreciated
Old Jun 18, 2005
Shifty's Avatar
i took mine from the tach test signal wire, its in a small black rubber box behind the passenger headlights, its the purple wire i belive. Check out the DIY for tach install. Goodluck!
Old Jun 18, 2005
perfect man..thanks for the quick reply
Old Jun 18, 2005
Shifty's Avatar
no prob
Old Jun 18, 2005
Man..i've been trying for about an hour to find this damn wire..PLEASE HELP!!! what box are you talking about?
Old Jun 18, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
I'de say he's talking ab the fuse box, but i'm not sure, gonna install a 5inch tach with shift light hopefually everthing will go smoth.
Old Jun 18, 2005
damn damn damn..anyone??
Old Jun 19, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
Hot of the presses, its the blue/ silver wire with the little rubber bootie in the loom that comes from the fuse box, its connected to the violet/white wire from my remote start. Lemme know if you need more help.
edit: In your second pic, its the blue wire with the yellow wire thats tapped into it.
Old Jun 19, 2005
so that's where i take my green wire form my tach and wire it to the blue wire. and that will work ?
Old Jun 19, 2005
Shifty's Avatar
its that little rubber box (not the fuse box). In ur pic its the one with the yellow wire in it
Old Jun 19, 2005
hmm..ok..we'll i guess my shift light may be broken because this is what i tried before posting the pics..hmm..ok thanks for the help i'll work on it
Old Jun 19, 2005
Overboost's Avatar
Overboost is an unknown quantity at this point
I pulled my speedometor out and plugged the wire to the little harness. Not sure which one it is put i just touched the wire to each of the little wires until the tach moved. I did it with the car on. If you need pics let me know and btw I have an LX which comes standard with a tach and just added another tach.
Old Jun 19, 2005
Overboost's Avatar
And clean your dirty little engine while your at it! hahaha
Old Jun 19, 2005
lol..i found what wire it is with my volt meter, but now my problems are getting worse by the day. On my tach, the needle does not light up nor does 4-6 rpm.
and yes i need to clean my engine bay..but i'll do it a couple days before turbo install
Old Jun 19, 2005
MYK1013's Avatar
yes, please.
Old Sep 21, 2005
sie7e's Avatar
sie7e has a little shameless behaviour in the past
Then man! what to you do??? I have the same problem whit the green wire. I connect in the test tach connector an dosen't work.
How you solve the problem???
97-DX-Lover
Jun 14, 2015 06:07 PM
Blazz
Jun 4, 2015 01:04 AM
cruisers10
May 12, 2015 10:46 PM
bo_red
Transmission
May 3, 2015 09:14 PM
dragonsblood
Apr 27, 2015 12:28 PM
