classifying amps
Old Jan 25, 2002
bake's Avatar
bake is an unknown quantity at this point
classifying amps
I've seen this a bunch of times, but how do u classify an amp ??
Old Jan 25, 2002
mohawkboom's Avatar
You mean like class A, Class a/b and Class D amps?..
Well a Class A Amp uses constant output transitors.. Which are always on.. but tend to get VERy hot..
Class A/B amps use a pair or more of transistors which constantly switch between themselves via MOSFET circuitry.
Class D amps Use Ultra efficient output transistors with very limited frequency range reproduction, Typically 20-200Hz . So they may only be used for Subwoofers.
Class "t" amps are just as efficient as class D amps but use 2 transistors at once. They use the typical Class D transistors to play low notes. A newer slightly more efficient transistor setup to produce 200-3.5khz and regular Mosfets for the highs. They also generally have Tightly would more efficient power supplies.. but are not as "clean" sounding as regular class a/b amps..
Hope this is what you're lookin for.
Cheers
Mohawk
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
