Matching Subs Rms With Amps Rms
Old Jun 8, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
The Rms Is The Rated Power Of Your Amp Or What Rated Power Your Sub Should Have. You Want The Rms Of Your Amp To Be Equal To Or More Than The Rms Of You Sub(s). This Way You Can Have Clean Non Destorted Power Getting To Your Sub. Inturn Your Sub Lasts Longer. Sometimes When Your Sub Blows You Fry Your Amp. If The Rms On Your Amp Is Higher Than Your Sub It Also Lets You Turn The Gains Down So Your Amp Strains Alot Less Allowing It To Play As Clean As Possible.
Max Power Isnt Anything But A Way To Convince Someone That The Black Sonys That Are 1200 Watts Max Lol Are Good Subs!
Old Jun 8, 2005
jttegx's Avatar
OMNES AD UNUM
Old Jun 8, 2005
shmik1's Avatar
I Dont Really Get Why You Capitalize All Your Words, Or Why You Felt The Need To Inform Everyone Of RMS, Which Is A Basic Thing You Should Know When Purchasing Amps Or Subs.
Old Jun 8, 2005
winnerpl's Avatar
winnerpl is an unknown quantity at this point
Old Jun 9, 2005
nick95673's Avatar
sorry capslock. and because in the past 2 days i have seen posts where guys have blown their subs and had amps that couldnt push them. yes i know i am captain obvious but it seems like alot of people really dont know.
Old Jun 9, 2005
playa6tnine's Avatar
playa6tnine is an unknown quantity at this point
its not caps lock if only the first letter in each word is capitalized
Old Jun 9, 2005
nick95673's Avatar
Caps Lock Is On Right Now As I Type This. And I Am Not A Teeage Asian Girl So I Dont Have Skills To Randomly Cap
Old Jun 9, 2005
Ed's Avatar
Ed
Your caps lock must be smarter than my caps lock. THIS IS HOW MY CAPS LOCK DOES IT'S THING. that's kinda cool really, do you have a program that does that? I don't think i'd start doing it or anything.
Old Jun 9, 2005
Big Rob's Avatar
I'm taking over!
Big Rob has a little shameless behaviour in the past
When your sub blows, you fry your amp? I have never seen that happen.
Anyway, it is okay to have less power going to your sub than the rms. What causes sub to blow isn't too little power, it is distortion. Some people feel that the sub isn't hitting hard enough, so they crank the volume causing the amp to work extremely hard. An amp that is being pushed all of the way will start to strain which will cause distortion and clipping. This distorting can acually cause an amp to start putting out more power than the max power rating of the amp because of the way that the unclean waves affect the signal. If you have an amp that has a power rating that is less than the power rating of the sub, the key is to send the sub as much clean signal as possible. If you have an amp with a power rating that is greater than the sub, then the key is to send enough power to match the sub's rms rating.
Also, the gain setting isn't necesarily for turning the power up and down. The point of the gain setting is to match the preamp voltage of you head unit.
Old Jun 9, 2005
nick95673's Avatar
i am sorry i didnt write that this is for newbies to car audio. the point of this thread is to save the folks who are still amazed that 4awg is larger than 8awg. no offense but everyone was there at some point. but for newbies its a good idea to get a amp thats rms is above the subs rms since most people honestly shouldnt even mess with their gains. Alpine is now hiding their gains under plates and they ask that salesman not tell customers that they even have gains.
Old Jun 9, 2005
MegaHurtz's Avatar
this thread sucks
Old Jun 9, 2005
MegaHurtz's Avatar
sorry but we dont need the sam old arguement
GolNat
Nov 27, 2018 03:32 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Bonobo
Oct 2, 2015 06:58 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
