radio removal for '02 rsx type S
Old May 17, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
hey guys, does anyone know how to remove the factory radio on an '02 rsx type S? I know this is an 7thgen forum, I'm hoping someone knows. If not, I'm headed to honda-tech....thanks guys
Old May 17, 2005
milk242's Avatar
milk242 is an unknown quantity at this point
clubrsx.com
Old May 17, 2005
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Radio Removal for the RSX is very similar to the 7th Gens.
1. Carefully pry and snap off the trim piece that holds the cigarette outlet in place located right above the cup holders. Careful not to bend it to much because it will break, pull outward.
2. Unplug the cigarette outlet plug and unbolt the (2) 8mm bolts that hold the radio bracket to the chasis, (exactly like our 7th Gens.)
3. Unsnap the Center dash piece however way you want to. I don't know if you ever took out your radio on your 7th Gen. Gen but they are a P.I.T.A. usually can push out from behind so you don't risk messing your dash up. This is very trick though but you will get it.
4. After you pop out the dash it is very straight forward after that, Again just like our civics. You're going to have to order that kit though because usually stereo shops don't carry the dash kit for the RSX.
5. Oh yeah I just noticed that you have a Type-S which is BOSE, so your not going to be able to use a regular Harness. You're going to have to either tap into the Bose Amp underneath the Passenger seat or run new wire to each speaker. I would rather integrate into the amp. I don't know the wire colors off the top of my head but I work tonight and can get those for you when I get home from work!
Good Luck
Old May 17, 2005
MegaHurtz's Avatar
copying thread to rsx forum
Old May 17, 2005
bradmanuwf's Avatar
Good Luck
yeah, I've got the dash kit and special harness already so don't go through the trouble of getting wire colors, I don't need them. thanks man....rep for you
mohawkboom
67
Aug 25, 2015 12:28 AM
mapdog
Jun 22, 2015 05:36 AM
TaiChi
Dec 17, 2001 09:09 PM
Ichiban
Nov 18, 2001 12:13 AM
Vtecpwr
Nov 11, 2001 10:17 PM
