Need help choosing components...
Old May 12, 2005
civicXXXX's Avatar
civicXXXX is an unknown quantity at this point
I'm trying to find a set of 6.5" components to fit in the front of my 2004 EX coupe, I did a few searches but couldn't find exactly what I was looking for. I checked on crutchfield but they only have 3 sets listed as fitting, there has to be more choices out there.
Has anyone figured out exactly how deep a speaker can fit in the door? or how much you can space a speaker out without worrying about the door panel fitting back on? This might make my search a bit easier. Thanks.
Old May 12, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
get Diamond Audio's for the components. The depth and the door panel shouldnt be a problem with most speakers. there is some room to play with
Old May 12, 2005
civicXXXX's Avatar
Anyone know if Alpine Type-S components (sps-171a) will fit in the doors?
Old May 12, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
CDT - 61a's at www.thezeb.com i was recommended these by J187 and i love them!!!
http://www.thezeb.com/p-CDT-Audio-CL...tem-101083.htm
Old May 12, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Maybe you have not seen the door speaker location yet, but nothing over 2
" will fit without a spacer and a good number of speakers will require metal cutting to get in there.
Old May 12, 2005
J187's Avatar
The CL-61As are easily the best speaker for the money. Its like eating filet mignon on a soft-taco budget.
Old May 12, 2005
patau13's Avatar
Big Member
patau13 will become famous soon enough
Don't be afraid to cut metal. I got a Dremel and it cut thru the door metal like magic. You can make any speaker fit with an afternoons work.
Old May 12, 2005
patau13's Avatar
Big Member
Don't be afraid to cut the plastic door panel either. Dremel goes thru it even easier, but then the plastic melts and makes a mess, so go slow.
I think the max mounting depth is 2 1/8th inch and the max spacer is 1 1/2 inch. something like that.
Old May 13, 2005
MegaHurtz's Avatar
Not only will they fit, but they come with the exact adapter that you need for a 7thgencivic so they are a great choice if you are looking for something cheap yet effective
Old May 13, 2005
TiM3's Avatar
TiM3 is an unknown quantity at this point
I just got Infinity Kappa's, but their kind of pricey and you'll need to do some metal cutting. By the way the speaker hole in the door is shaped, I think you have cut metal regardless of which components you get.
Well I guess except for the Alpines.
Old May 13, 2005
tripledoublegs's Avatar
Euro-Spec
How do you like the kappas? My friend has the perfect components, and he was saying people like the kappa series more.
Old May 13, 2005
J187's Avatar
If I remember, the Kappas had more midbass.
Old May 13, 2005
chrisavs's Avatar
chrisavs is an unknown quantity at this point
alpine type s or infinity kappas, those are my fav, and yea you can make them fit, just takes a little labor to do it.
Old May 13, 2005
chicohonda02's Avatar
Since 2002 Baby!
Boston's all the way, they kick ***.
Old May 13, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
i have type sps171a in my 01 lx with dyna mat around and have no problem its a close fit but its a fit
Old May 13, 2005
TiM3's Avatar
The Kappa's are extremely clear. If you like treble as much as bass, these are the ones to get. The mid base is decent but the high's are what this component excels at.
Old May 13, 2005
Euro-Spec
damn, I would really like to hear the kappas and perfects side by side.
Old May 21, 2005
sl1982's Avatar
sl1982 is an unknown quantity at this point
type r
Does anyone know if the alpine type r will fit? Ive heard mention of the type s but i already have a set of type r's. Also it is a leased car so i dont think i can get away with cutting metal.
Old May 21, 2005
se04civic's Avatar
se04civic is an unknown quantity at this point
I have JL Audio XR650-CSi mounted and they sound really good. I had them just wired up to the deck and they sounded ok. Then I hooked them up to a JL Audio 300/4 and they sound great now. All you need to make them fit is a spacer.
Old May 21, 2005
chriscivic's Avatar
chriscivic is an unknown quantity at this point
i put alpine type r's in. I bent the sheetmetal in the doors back to make the hole round and then used 3/4" mdf and cut out round spacers. i mounted the mdf to the doors, then alpine's plastic mounting ring to the mdf, then the speakers go right in. i also cut the plastic that sticks out around the speaker grill on the door panel to make sure the speaker doesn't hit the door panel. took about 2 hours total to install. best buy told me there was no way possible for them to work. but they sound alot better than the sony xplode 6 1/2's i had in there. i got the alpine cda 9825 hu and a tsunami 4 channel giving them 75 rms a piece.
Old May 21, 2005
eye_see_you's Avatar
let the devil out
so far from what i've seen all 2000 up civics will fit 6.5's in the door with spacers so just take your pick.
Old May 21, 2005
fergsonfire's Avatar
Kung-Fu Kar Kare Master
fergsonfire is an unknown quantity at this point
JL components theirs and Eclipses sound bad ***
Old Jun 21, 2007
lwebb12's Avatar
lwebb12 is an unknown quantity at this point
Re: Need help choosing components...
What thickness size spacer did you use?
OptimisticWay
46
Oct 15, 2015 02:16 PM
General DIY
Sep 25, 2015 08:02 PM
Bonnabell
Aug 14, 2015 04:15 PM
