Would this sub/amp combo work?
Old May 10, 2005
Zerostatic's Avatar
Zerostatic is an unknown quantity at this point
First of all, I got an Acura CL not a civic, but that doesn't really matter much.
I was thinking about getting a 4 channel amp to power my system. I was thinking of bridging two of the channels to power a sub, and use the other two channels to power my front speakers. I just wanted to know if the follow specs look like they'll work good together (i.e. do the wattage output on the amps and the wattage on the subs look str8?)
4 Channel Amplifier Specs (600 watts max power)
60 Watts x 4, at 4 ohms <= 1% THD+N
150 Watts x 2, at 4 ohms BRIDGE <= 1% THD+N
12inch sub specs
MAX. Music Power 400W
Nominal Power Handling 100W
PS, I didn't give brand-name cuz i don't want this to turn into a recommendation of specific brand amps or subs I just want to know if this combo looks like it'll work together.
Old May 10, 2005
ajhdragon's Avatar
7thgens official a$$hole
well if yo udo this you will not be able to tune your sub diffrently from your speakers you hook them up to. but i guess it should work.
werdnahall
May 17, 2015 11:37 AM
ORskier
May 3, 2015 12:54 PM
nemesys6
Dec 20, 2001 02:11 PM
artychris
Dec 7, 2001 02:01 PM
DarkCivic
Dec 1, 2001 08:51 PM
