Speaker wire into front doors?
Old May 6, 2005
Rollingstash's Avatar
Rollingstash is an unknown quantity at this point
I'll be running 4 conductor 16 guage speaker wire into the front doors of my 01 ex coupe. Is there room in the factory accordion tube for extra wire or will I have to drill? Has anyone else run speaker wire into the doors in this way?
Old May 6, 2005
paradoxblue's Avatar
theres a diy.. but if u remove the stock.. and runt he wire threw the harness. drill out the clasps tor un it through it is possible.
Old May 6, 2005
stepchild's Avatar
stepchild is an unknown quantity at this point
I have an LX 01 and on mine there is actually a hole in the acordian gasket/gromet at both ends of the acordian. I ran my speaker wire throgh there but I only ran 14 gauge single(dual conductor) connection. hope that helps...........
Old May 6, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
You can easily fit 16-4 through the rubber tube. Just do yourself a favor, instead of spending an hour and a half trying to snake the wire thorough at strange angles. Unplug the harness that runs through the rubber from the factory under the dash and pull it through the hole. This will allow the rubber to come free from tension and you can slip your wire through no problem.
Old May 7, 2005
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
My friends and I pulled some 12 gauge through the door grommets using a coat hanger to pull it through. There's a decent amount of room in there, you shouldn't have too much trouble.
Old May 8, 2005
MegaHurtz's Avatar
I did 2 pairs of 12 gauge speaker wire into my doors thru the factory accordion thing with no probs. Tied the wire to a straight long piece of coat hanger and fished it thru. PITA at first but once I got the hang of it, was no problem
Old May 8, 2005
tripledoublegs's Avatar
Euro-Spec
yep, that's the easiest way to do it. I just ran some 14awg wire today to replace the tiny stock ones. Also ran my tweeters with 16awg. There's plenty of space
Old May 8, 2005
Awesome, that sounds easier than the last car I did. Thanks everyone!
Old May 8, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
14 awg is good enough right?
MamaBear2015
May 18, 2015 07:37 PM
werdnahall
May 17, 2015 11:37 AM
MamaBear2015
May 3, 2015 02:17 PM
Hondasport01
Dec 6, 2001 11:58 AM
doublins
Nov 11, 2001 07:01 PM
