What Size IDMAX?
Old Apr 27, 2005
craiger's Avatar
craiger will become famous soon enoughcraiger will become famous soon enough
What Size IDMAX?
Alright, I'm in the market for an IDMAX. I'm not quite sure on what size sub I should go with. I mostly listen to music with a lot of fast double bass drumming. Now, I know a 10 will keep up just fine with it, but I miss the low end of a 12" sub. Should I go with a 10" idmax and port it, or should I go with a 12" idmax in a larger sealed or the smaller ported box? I will be getting the D2 V3 so I can run my HCCA 250R at 1ohm which will be putting out just over 1000 watts.
What's your take on this?
Old Apr 27, 2005
shmik1's Avatar
unless ur getting it off ebay, have fun with the backorder, i've been waiting for mine from sounddomain for over a month, however when i ordered it they had additional savings + free s/h.
if they still have it u should order now to get the deal, im getting a 10"
I'd go 10" ported if u miss the low end of a 12.
Old Apr 27, 2005
fonto's Avatar
The LA Clipper
Yeah, IDmax are always back ordered...I was lucky that i only had to wait a week.
...if the authorized dealers are having a hard time keeping them in stock, then I doubt that any authorized dealers will really have them
Old Apr 27, 2005
craiger's Avatar
are you getting the 2 ohm or 4 ohm sub?
I have a 10 hcca subwoofer in a ported box right now. don't get me wrong, the sub gets low, but it doesn't pack the punch like a 12" sub does.
I just don't know how the hcca and the idmax compare to each other.
Hmm, maybe i should just go with a 12" then.
Old Apr 27, 2005
shmik1's Avatar
2ohm
Old Apr 27, 2005
fonto's Avatar
The LA Clipper
I have two 12 Dual 2 ohm subs...and I have them wired together into a 2 ohm load
Old Apr 27, 2005
Regularjoe's Avatar
Regularjoe is on a distinguished road
I'd say the HCCA is a SPL sub where the ID is a SQ sub. Totally different types of subwoofers. If you want more volume than the current 10" ..... I'd think you want a pair of ID's .....
Old Apr 27, 2005
craiger's Avatar
Fonto, how many watts are you running to each sub? I would love to run 2 12"s a 1ohm. But I don't have that kind of money right now.
Old Apr 27, 2005
fonto's Avatar
The LA Clipper
probably between 1100-1200 watts, using a JBL Crown BPX 1100.1
...so around 600 each.
68camerors
Sep 24, 2015 06:18 PM
