Flip out DVD Players working while driving
Old Apr 26, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
I was wondering what Flip Out DVD Players/Cd Players will play movies while the car is in motion. I've heard the new Pioneers have something that won't let them play while the car is going faster than 5 mph. I was wondering if the last year models would work. Or the new Clarion would work. Anyone help me?
Old Apr 26, 2005
runner1738's Avatar
the thing is to bypass what is usually controlled by the e brake, instead people ground out that wire i believe, but search and youll find a lot more, also on the new pioneers it has a gyroscope in it i believe that makes it harder but not impossible to do , or so othes have said.
Old Apr 26, 2005
diskreet's Avatar
you can wire any of them except the one kenwood or whatever it is, maybe pioneer, with navigation.
otherwise the alpines need a little box to trick them, and all others are usually just grounding a wire.
Old Apr 26, 2005
Does anyone know anything about the Clarions? CLARION VRX925VD or the VRX755VD and the VRX745VD, can you buy a bypass switch for these or will they work?
Old Apr 26, 2005
diskreet's Avatar
picture above your post is VRX745VD. I know all you have to do for this one is ground the dark green wire. I grounded mine INTO the wiring harness but i have a switch so that if i get pulled over i hit the switch and it says "Audio Only" and i dont get ticket.
Old Apr 26, 2005
You grounded it to which wiring harness? Have you been pulled over before and been asked to show it?
How about the 755VD? Does it work the same way or did they do something to make them not work?
Old Apr 27, 2005
paradoxblue's Avatar
drew.. grounding means grounding lol.. he jsut chose the gronud on the harness.. i could hot glue it to a bolt if u needed haha
Old Apr 28, 2005
I just asked which harness he grounded it to, i know what grounding is, i didn't know if there was a certain place to ground it to
Old Apr 28, 2005
diskreet's Avatar
I grounded to the wiring harness for the HU to keep wire mess to a minimum and complication to a minimum
Old Apr 28, 2005
MegaHurtz's Avatar
it's illegal to do this, so sorry thread closed
Xuhme
21
Aug 7, 2023 03:40 PM
ORskier
May 3, 2015 12:54 PM
smmahan
Apr 15, 2015 08:17 PM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
