Amp question?
Old Apr 25, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Amp question?
I am going to be running 2 12" infinity perfect 12.1D subs. I want to power them with enough power, 350rms 1400 peak 4 ohms. I want a good amp but i dont wanna spend $1,000 on an amp. I cant find any subs that are 4 ohm and that have enough power.
So the question is...
How many amps should I run to power my 2 subs with enough constant power and to power my speakers. Where can I get good amps at a decent price?
Old Apr 26, 2005
LiKEaFeRiO's Avatar
You need to decide on how you want to wire up the subs.
Theres so many amps you can use because with 2 4ohm dvc subs, you can have them wired up at 2ohms x2, 1ohm x 1, or 4ohm x 1.
I'd look for a nice 1ohm stable mono amp that's close to 700rms @ 1ohm.
Or a 2 channel amp that can pump out 350rms @ 2ohms x 2.
Old Apr 26, 2005
jeffsta17's Avatar
ok so it would be ok to run a less ohm'd amp, if that is the correct terminology lol.
Old Apr 26, 2005
LiKEaFeRiO's Avatar
Yes that's okay.
An amp running at 700rms watts @ 4 ohm x 1 would more than likely run 1400rms watts @ 2ohm x 1.
So getting an amp running at 700rms watts @ 2ohm x 1 would be more cost effective (cheaper) but still allow you to get the same power.
Old Apr 26, 2005
jeffsta17's Avatar
Alright thanks man
Old Apr 26, 2005
jeffsta17's Avatar
for wires, what kind should I get like is there a specific brand that is the "best" or something. Im gonna do monster cables for RCA's but do they make the rest of the wires too?
Also I think I found an amp but its RMS is 370 and 4ohms, is running 370rms gonna kill my subs which are rated at 350rms. I will be playing them everyday for atleast 3-4 hours a day.
Old Apr 26, 2005
LiKEaFeRiO's Avatar
Just make sure the wires are thick enough to handle the power.
Old Apr 26, 2005
jeffsta17's Avatar
yeah it said 8 gauge, but is there any good brands, like "streetwires" or whatever that you would reccommend
Old Apr 26, 2005
LiKEaFeRiO's Avatar
I really don't see a difference between expensive Monster Cables and the generic stuff on eBay. 8 gauge speaker wire is 8 gauge speaker wire.
I just don't think most people will notice the difference between one brand and another.
No one runs anything high end and crazy enough to hear a noticeable difference, if any.
Old Apr 26, 2005
tripledoublegs's Avatar
Euro-Spec
don't worry man, my best friend has the same subs you got, perfect 12.1 and he gave them close to 500w rms to each, for a while... those subs are definately underrated. 370W should be perfect.
Old Apr 26, 2005
eye_see_you's Avatar
let the devil out
8 gauge wire to the subs and wire them up however you choose. the 370rms is not a worry when you have them wired together.
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
redcloud
25
Aug 12, 2015 01:23 PM
Civic65
Jul 19, 2015 10:13 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
