Alpine help from the pros
Old Apr 25, 2005
CplJon's Avatar
Rape is no laughing matter--Unless your raping a clown!
CplJon will become famous soon enough
I had the 9853 installed last week, and I'm having a hard time understanding the EQ.
PROBLEM 1: I've attempted to set the EQ but the mid bass is very loud and there are practically no high's. As well as the midbass being loud it sounds similar to an AM radio.
PROBLEM 2: Is the built in crossover conflicting with the amp crossover? I also have a Directed active crossover that is currently only hooked to the subs, will hooking up the interior amp to the Directed crossover help or conflict with the built in crossover. To further complicate things, I also have an Audiocontrol Three.1 EQ. That EQ utilizes 8 volt preouts and all of the RCA's are hooked up to the Audiocontrol, so only one set of RCA's is plugged into the head unit. The RCA from the EQ is plugged into the FRONT set of pre outs from the HU. When the Audiocontrol is set at its highest setting for the Highs, it still barely has any sound coming from the tweeters.
If anyone has used the EQ/crossover in the 9853 or might be able to help, I would appreciate it!
Old Apr 25, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
First off, I think it might help you to understand that EQs are used primarily to fix systems that don't sound right on their own. You should try to limit the number of additional devices that you have in you system, especially active and powered devices as they will raise your noise floor and potentially hinder the performance. You should try a couiple of things in my opinion. 1. Use the defeat option on the Alpine and see how it sounds without any internal processing from the head unit. 2. Try to install your system as raw as you can - headunit, 3 preouts, passive xover for componets, amp crossovers for subs. Then add attitional EQs and xovers if you need. 3. Once you've got it about right. Take advantage of Alpine's I-Personalize tehcnology from their website www.Alpineusa.com and set up the internal settings in your hU. OR, If it's good the way it is, you can run the headunit on Defeat as I have my 9833.
Old Apr 25, 2005
CplJon's Avatar
Yeah, I figured the EQ could be a problem but I installed it a couple years ago to run with my stock head unit after a kenwood X815 **** out on me. I like it for the 8v preouts and the line driver, and the active crossover was only put in for the subsonic filter on the subs. Would it be better to use the graphic EQ or the parametric EQ on the HU? Also on the bottom of the stereo there is a switch for 2-way and 3-way, does this play a large role in tuning it? I have a setting configured on i-personalize but I need to rip it onto a cd and put it in the HU, will do after work.
Old Apr 25, 2005
J187's Avatar
I'm not exactly sure on the 2way or 3way, you'd have to read I'm not familar with it. But the 8volt preout might not even be good if you can't match it with an amp that has an 8v input. In Fact, I'm willing to bet it's no better than a 4v preout. I personally would try to eliminate all devices from the sytem and start from scratch.
Old Apr 25, 2005
CplJon's Avatar
Thanks for the input, its all for the greater good of loud, clear, ear-wrenching music to **** off the neighbors who have 4 families in a single family house, after all, I do live in Texas.
Old Apr 25, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
the cause of your lack of highs could be attenuated crossover settings on the headunit. Try setting the EQ to flat and the xover to flat. If you still have an issue it's probably your external equalizers.
Old Apr 25, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
just curious but does anyone actually use the ipersonalize?
i find that changing settings in the hu is just as easy..
Old Apr 25, 2005
Mystic3030's Avatar
I just do it in the HU...
krazykoncepts
Sep 8, 2015 09:02 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
