current problem/flickering lights
Old 04-21-2005
01civi's Avatar
01civi is an unknown quantity at this point
I looked but didnt find anything(just my luck probably) but I was wondering what you guys are doing to stop your lights from flickering. I currently have a batcap and a optima battery.
Old 04-22-2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
ok and what u running in your car?
Old 04-25-2005
01civi's Avatar
visonik 3909(300x2) running a audiomobile DVC 10"
Old 04-25-2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
get hid's, boom no more flickering
Old 07-16-2005
zen_master's Avatar
bring this up from the grave..
i just realize today...that my system are flickering..
i mean, everything, front, back, inside, tach....even when my audio are turned off....
any idea??
Old 07-16-2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
check your connections at the battery, I'm willing to bet the connections at the terminal are corroded
Old 07-16-2005
zen_master's Avatar
hm...yea, i think i have to..
btw, which connection? both?
EDIT....i hope this is the one though...even though i kinda doubt about it..
btw, the negative terminal in my car doesn't have the red cover anymore because of the amp cable.....
is there any way i can close it up? i've been looking for bigger plastic cap..
Old 07-16-2005
yup, check both connections. The negative cable shouldnt have an amp cable on it. If your talkin about your positive cable, not having the cover isnt a big deal. Once you get the terminals clean, apply some di-electric grease to them to keep them clean
Old 07-16-2005
zen_master's Avatar
oops...it's the positive terminal. LOL..
yea, i think i'll do that tomorrow....following what the haynes book said about cleaning the terminal...using that metal brush....and later on, i'll cover it with lots of grease..
Old 07-16-2005
that'll definatly help. make sure you dont use regular grease, it has to be dieletric grease. If your feeling lucky, upgrade your factory grounds. it helped my system out alot.
Old 07-16-2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
upgrading the grounds helped mine too.
Old 07-16-2005
vietstylez's Avatar
flickering?? or dimming
Old 07-17-2005
zen_master's Avatar
flickring....blipblip--blip--blipblip..
well, actually.....it's better now after i drove it for couple miles...
i didn't (forgot) to tell u guys....but i was using the dome light for lighting for 1 or 2 hours....i was doin my rear panels and subs.....
maybe that weakens the battery?
im using stock battery FYI
PinkCupcakes
Electronics
07-18-2019 12:50 PM
eorlando1
05-17-2015 11:16 AM
intensity
05-12-2015 10:43 PM
tylerginevan
04-27-2015 12:29 PM
dooner24
04-14-2015 07:51 PM
Quick Reply: current problem/flickering lights
