Kicker L5 Or L7?
Old Apr 18, 2005
hatfield009's Avatar
hatfield009 is an unknown quantity at this point
Kicker L5 Or L7?
Is Kicker Good I Just Saw A Truck With It And It Sounded Great I Was Wondering How They Werer He Had To 12 L5's How Are The L7's Are They Good?
Old Apr 18, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
I personally would not go with L5 if your looking for tons of bass, both sound the same, the L7 is higher power handling. If you got the bucks go SOLO-X 10",12",15".I got my SOLO-X12" for $600.00. Has a rms of 2000 sealed,5000 rms spl.
and before someone disputes this, I got this from kickers site:
http://www.kicker.com/05/05kicker.html
Old Apr 18, 2005
well i dont wanna go solo x i got the bucks but i dont wanna spend 1000 for a sub.... so they both sound the same but the L7 is louder i guess?
Old Apr 18, 2005
ex_03's Avatar
Godlike member
Not really, just will handle more power. If you have a small amp. go L5.This also depends greatly on what enclosure you build for it as well. for the L5/L7 the ported enclosures are the way to go, If you the space. You can check it out at there site.but the ported enclosure is quite large. And I will admit when I called kicker techs on how big I should go with my solo he told me as big as possible, So I was like 3.25 he said yes, and thats sealed. He said not to follow the manufactor specs. And he was right becuase it sounds great in a large sealed box.
Old Apr 18, 2005
i dont have an amp im going to buy the whole system real soon.... what amp you recommend for the L7
Old Apr 18, 2005
ex_03's Avatar
Godlike member
again I have to give you my opinion, I guess depends on how important this is to you. If dont want to go thru upgrading the entire cars electrical, go with a class d amp for your sub, there cheaper and way effecient when it comes to making big power. there are alot of threads covering brand names. Most companies make class d amps, so I guess its preferance. I can name a hundred of them, you have to match the subs voice coils with the amps resistance allowance. If you get the dual 2ohm you can almost get any class d amp that runs at 1ohm mono. If you get the dual 4ohm you would have to get an that runs at 2ohm mono. The difference isnt really the issue again its more or less what you want. If you decide to get the kicker sub just go with the dual 2ohm and any class d amp. L5 go no higher than 750 rms, L7 go no higher then 1500 rms.
Old Apr 18, 2005
ex_03's Avatar
Godlike member
just keep in mind that a cheap made amp is cheap for a reason. Do a little research. Youll see that JL makes great amps, Rockford used too I dont know about now.Kicker makes decent amps, earthqauke makes some decent class d's. MMats audio used to make some sick class d's.
Old Apr 18, 2005
what do you mean about upgrading all of the cars electrical? well i just want what would be the best that would make the subs sound best they could im going to get everything like mids n highs and everything
Old Apr 18, 2005
ex_03's Avatar
Godlike member
Well thats what I mean, Are you running two amps? Are you changing all the inside speakers? If you plan on running two big amps you'll have to do something on the electrical side of the car, The stock electrical is made too handle the vehicle and maybe a sub amp. But it depends on what you get, If you get a 1200 watt rms class D amp and 400 rms 4 channel for mids and tweets your definitly going to have upgrade..Batt..Buy a cap..Best thing to do is buy what you want install it and go from there!
Old Apr 18, 2005
yeah im going to do 2 amps n the door speakers... how much would be a cap be? how much would that 1200 watt class D amp cost for a good one?
Old Apr 18, 2005
ex_03's Avatar
Godlike member
look around ebay good place for caps and amps. just look for those specs as for the cap you'll need at least 1 to 2 farad. Shouldnt need more than two farad.
Old Apr 18, 2005
alright.. i was lookin at your cardomain site couldnt i just get an extra battery just like you did?
your car looks good too
Old Apr 18, 2005
ncirom2003's Avatar
id say go for rockford fosgate amps, if they are still good. my RF amps are seriously 10 years old my bro bought them in early 95 and they work wonderful. he said in their day they were some of the best and people were using them for competition level
Old Apr 18, 2005
ill look around to see if those fosgate amps are good still...
Old Apr 18, 2005
04trinicivic's Avatar
04trinicivic is an unknown quantity at this point
Look man i work @ circuit city doing nothing but installing **** in cars all day. get the l7's the hit hard as hell but u jus have to get a good amp. if u want em to hit real hard drop em in ur tirewell and get and amp for each. i promise u there will be no disapointmentsssssssss.o and the solo x hit real hard i had a pair in my civic but i sold em cuz they blew out my back window 2 times.......
Old Apr 18, 2005
well i was wonderin about doin that for the subs puttin them in the tire well but i asked a guy at cartoys and they said that it would cost a ton and that they werent even sure if they could do it, wouldnt an amp for each one and an amp for the door speakers be expensive?
Old Apr 18, 2005
ex_03's Avatar
Godlike member
yea they had great designers then! Those amps could be ran @ like .02 ohms mono the circuit boards would melt and the damn thing would still be playing!
Old Apr 18, 2005
ex_03's Avatar
Godlike member
one sub amp and one fourchannel is the way for you to go. but I can tell you to do it right your going to need at least this:
1 or 2 subs
4 coaxial speakers or two sets of components 5" or 6"
amp for subs
amp for highs
at least 4 guage wire kit or 1/0 guage
cap and or battery upgrade
it can start to get costly.
I didnt just get an extra battery. I have my stock battery up front, yellow top in trunk, and 15 farad cap.
Old Apr 18, 2005
steak84ss's Avatar
steak84ss will become famous soon enoughsteak84ss will become famous soon enough
Unstopable Combo = JL 10 or 12 W7 with Phoenix Gold Amps. I personally feel that the 10W7 I have in my Integra is one of the best subs I've ever heard.
Old Apr 19, 2005
well i agree those subs are nice but everyone has JL and they are pretty expensive too...
i called around places and i got 299 for the lowest for a kicker L7 that good??
Old Apr 19, 2005
ex_03's Avatar
Godlike member
no not really. I get those for 200.00 in michigan, where are you?
Old Apr 19, 2005
02blackcivic's Avatar
02blackcivic is an unknown quantity at this point
i say l7's, my friend has em n they sound bad a$$
Old Apr 19, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Bullshit...
1. A cap will not do a damned thing except keep your lights from dimming. It's going to do nothing for your electrical system.
2. I've personally ran 1450 watts off of the stock electrical with absoloutely zero problems. (JL 500/1, JL 500/1, JL e4300 (2X150 @ 4ohms for front components) , and JL e2150(1X150 @ 4 ohms for center channel) ). I know it'll run it fine.
3. Other members here have ran up to 2 kw (maybe more) (included in that list, if I remember correctly, are Ludlam theroy, White Rabbit, and Mystic 3030 to name a few, I'm sure there are tons of others).
The best thing to do is buy the gear and see what happens when you install it (electrical wise).
Personally, I hate Kicker's L series subs. They're overpriced for the way they perform. If you want to block rock, they're probably a good choice for you, assuming you're comfortable paying that much for them. I'd go for something else, but that's my opinion, and opinions are like a$$holes, everyone has one.
Old Apr 19, 2005
ex_03's Avatar
Godlike member
Originally Posted by PopcornPlaya
Bullshit...
Oh I forgot about the experts here!!!. You guys know what I meant he'll need one most likely but hay you know everything just like all the other fnn know it alls..LOL you guys kill me.fnn kids tell me im wrong, been installing a few years, And I notice all you do is disagree with guys like me constantly...fn kids..lol
Old Apr 19, 2005
ex_03's Avatar
Godlike member
how the f*** do you know what his car is going to do? Are you going to install it popcorngangsta? I dont think so so shut the F*** up!!!
Old Apr 19, 2005
ex_03's Avatar
Godlike member
And everyboard has there *******s!!
Old Apr 19, 2005
ex_03's Avatar
Godlike member
And you obiviously dont even read my threads I never said a cap will add power, It will however help the electrical as far as the alternater suppling the whole car if the amp draws of the battery and the battery is not enough where else does it get power from? the alternater. So instead it gets stored power from a cap. Do your self a favor and dont listen to these guys there just pissed becuase they can't afford to do things right, If you under power your amps you'll run the risk of destroying the amps powersupply, ask any professional in the business, call rockfords tech line even JL's the'll all tell ya the same thing.
Old Apr 19, 2005
ncirom2003's Avatar
Old Apr 19, 2005
ex_03's Avatar
Godlike member
well Im just saying having an opinion is one thing saying that someones advice is bullshit, the guy didnt even read the whole thing obivously, I told hatfield to buy everything install it, and if you have no problems then dont bother with a cap or yellow top. But I notice when people even mention cap all the experts chime in just to say there unwarranted. Thats just no true, there needed in some cases. Not ever car's electrical is the same. But like I also said call the munafactor's tech support they are there to help you with any and all questions about there products and believe me they know more than anyone here about there products.
Old Apr 19, 2005
i live in fort worth, texas
