Need Help
Old Apr 13, 2005
celwin's Avatar
celwin is an unknown quantity at this point
Need Help
I installed some components and woofer over the weekend. Here are the problems.
1. The volume will sometimes just increase and decrease by itself without me adjusting anything
2. The sub has this sound I can only describe as taking a sheet of paper and hitting it. It's only audible when you are close to the sub. In the cabin I do not hear it at all. Is this normal? Sub is Elemental Designs 11kv2
Is the volume issue amp or head unit related? Never had any problems with the HU before.
Old Apr 13, 2005
tripledoublegs's Avatar
Euro-Spec
did you install an amp for the speakers also?
Old Apr 13, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Are your rca's twistedpair or just tripleshielded?
Old Apr 13, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
sounds like something is causing the signal to clip
Old Apr 14, 2005
paradoxblue's Avatar
check your amp tunr out. mine was scraped bare and grounding and it was causing odd noises.
also i'd invest in high end rca's if u havnt.
sure you didnt pop something in the sub or did they maybe come factory ****ed?
Old Apr 14, 2005
celwin's Avatar
The components are amped yes. Amp turn out? What's that? RCAs are twisted. Came with the Rockord Frosgate amp kit. The sub is brand new bought directly from Elemental Designs.
Old Apr 14, 2005
Euro-Spec
what kind of amp is it?
