New audio setup begins!!!(Updated!!!)
I'm actually trading my blue and black racing seats for them. But i'm paying the shipping for both ways. I've been tying to get them for months so it's a fair trade to me. But the best ways to find some are either ebay or clubrsx.
Well I just finished the second part so let me know what you think. Also was wanting you imput on my trunk carpet. My car is blue and my interior will be black and silver so any suggestions on a trunk carpet color?
plywood is great as long as you are not making a box with it... mdf is heavier than a son of a bitch and plywood is lighter than ****, so it keeps the weight down, and there is no real reason to use MDF when wood is only needed for cosmetics and not strength, unless you have a reason to?
I know. I paid $100 for the whole sheet of mdf so I'm going to use it as long as it will work instead of buying more wood just so it will be lighter. With all that I'm putting in, I'm really not worried about the weight
I need TP for my bunghole
I can get one at home depot for $22.00
Kung-Fu Kar Kare Master
I agree, please tell me that is not duck tape. If it is, I applaud you on your work so far and also think you are insane. Also, might recomend puting some tap on your paint when glassing, also if you are glassing the rear deck in place, tape the window.
no offense, but that is the worst everything i have ever seen, i hope this is a joke!!!
duct tape? that armstrong stuff literally isnt doing anything if it isnt actually stuck to the metal which in your case it isnt!!!!
looks like alot of wasted time, i think you just got lucky that it didnt rattle because that **** aint helpin bro.
sorry to burst anyones bubble with this post
I see you have made some progress. That's good. So far everything looks like it's coming along. I'm awaiting some further pics. The only thing I can see that I might poke at a bit, is the armstrong SD material. It seems that after all is said and done, you havne't spent much less than you would have if you'd bought some nice Edead on ebay. 100Sq ft of edead is equivelant to about $83. Edead is the stickiest sound deadener I have ever seen and I'd say the most effective I've used. It's easy to work with with, cuts nicely and contours very well. The armstrong you ended paying what, $88 with the spray adhesive?? You ended up with an inferior deadening product, harder to work with due to thickness and much more of a PITA because you had to apply your own adhesive. Furthermore, although the Anderson stuff may stop rattles, how effective is it at preventing resonation? Does it prevent pressure sound levels from being drawn into trunk panels? I'm sure the jury is still out. Either way, it just seems like a less efficient way than using Edead, that's all. No big deal, just an FYI. Other than that, keep it comin' Looks like it'll be a very nice design!!
your pictures show that you got corners of the armstrong flaring all, up it doesnt look stuck down well, its looks like it took a lot of time having to glue it all down and end up looking like that. it doesnt even look likes it going with the countours of the metal panels.
and why do you have to have smooth edges anyway? it doesnt matter.
its not the duct tape that bothers me, i use duct tape then masking tape over that when im protecting things that i glass over.
i was just saying its the worst ive seen but if it works it works. im all about attention to detail so wheni se that i cringe.
but thats me not you so im glad it worked out for you. good luck on your project
Yeah I did buy MDF. Works great so far. it's 3/4" by the way, went with the wood suggested in the Custom sub trunk DIY on here.
Originally Posted by MegaHurtz
then why did you make your box out of plywood?
Raiool
Oct 1, 2015 10:42 AM
raymondxcho
Sep 29, 2015 09:00 PM
