Ipod mini install?
Old Apr 12, 2005
czechcivic's Avatar
czechcivic is an unknown quantity at this point
Ipod mini install?
I wanted to hook up my Ipod Mini directly with those monster wires they sell to hook up to your home stereo, I have a pioneer avh-p6500dvd by the way...I thought I could just hook it up to the brain and go to aux. and it would work but it didnt...Should it work or is there another way to hook itt up directly?
Old Apr 12, 2005
zachgeyer's Avatar
Rca ports
Old Apr 12, 2005
czechcivic's Avatar
I hooked it up to the rca ports in the brain, it seems to not of worked.Unless I did it wrong but I dont see how
Old Apr 12, 2005
Big Rob's Avatar
I'm taking over!
Big Rob has a little shameless behaviour in the past
Is the aux input turned on? I had to turn mine on. Also, make sure that you are hooked into the aux input, not the output for the amp. I have a regular ipod hooked up to my pioneer deck through the "brain" and it works fine.
Old Apr 12, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
isn't there output rca's and input rca's? Make sure you're using the right ones.
Old Apr 12, 2005
es2k2's Avatar
Proud to be a civic owner
will the ipod interface adapter from pioneer works for ya?
http://www.crutchfield.com/S-5q2xpCe...0&I=130CDIB100
Old Apr 12, 2005
Dlmille's Avatar
Dlmille is an unknown quantity at this point
Yeah the AUX input should work just fine. Just remember to turn the input on!
Old Apr 12, 2005
Big Rob's Avatar
I'm taking over!
I just looked up your deck on crutchfield and it said that the aux input is optional (meaning that you need an add-on accessory to make it work). My pioneer deck is the same way. You need to get something like this: Pioneer CDRB10. There are also others that allow you to hook up satelite radio and a cd changer.
Old Apr 12, 2005
czechcivic's Avatar
do you know for sure if that is the exact part I will need to hook it up....Oh and what are those outputs coming from the brain(or whatever its called if there another name for it) for.......Just for amps?The guy that installed it said I could hook up a playstaion to it there so they must be inputs right?
Old Apr 12, 2005
czechcivic's Avatar
oh yeah these are the wires I bought.....These would be what I want correct?
Old Apr 13, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
might want to check this out for ipod installs.
that dude is really good w/ ABS plastics. theres another installs for ipod, chcek his site out. ppl w/ civic coupe might want to try this for that lil space by the ebrake or cup holder on sedan(might not be a best choice but just an idea).
Old Apr 13, 2005
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Pioneer decks need the IP-Bus Interface cable to make AUX audio inputs. I don't know how your specific model works but once the cable is hooked up turn the head unit off, hold down the function button and a menu should come up that will allow you to select AUX: on or off. Good luck
Old Apr 14, 2005
typeRDreamer's Avatar
typeRDreamer is an unknown quantity at this point
So you dont need to adapter or nething?
OptimisticWay
46
Oct 15, 2015 02:16 PM
