Major Porblem!!!!!!
Major Porblem!!!!!!
Well Here it is I have a Pioneer Mp8500 (Mp3 Motorized) Jl 500/1, JL W3 v2 D2-12". I just hooked the amp up over the weekend and everthing was fine. Except that my Fm/Am radio wouldnt work at all except for one station 98.1 CHFI when I unhooked the amp all station slowly came back. Here is how my wiring setup is, my power wire and the anntena (sp) is on the same side (passenger side) the RCA & Remote wires are on the driver side. Could it be that the high current from the amp is interfering with the signal from the anntena??? My old setup was a Alpine Mrd M300 and the same HU and deck, and never had this problem before. Can someone please help me????
Thanks alot,
Slimmkidd
Thanks alot,
Slimmkidd
Your amp doesnt transmit so thats definetly out. sounds like your ant cable is unplugged some where?
maybe not behind the radio but somewhere else.Are you sure that you plugged it in when putting the radio in,or did it fall out when you moutned radio?
did you hook up power antenna wire to your deck? I know we don't have one, but it needs to be hooked up for the antenna to work at its full potential.
No, I am saying "If your car doesnt have a power ant. why hook up the ant turn on for?" The radios ant out put wire is for triggering a power ant. for up and down. Thats it. I guess what im asking is from the radio to your car you guys are saying to connect the ant. turn on wire?
Damn that might be it!!! I will try something tomara after work!!! does this mean I goota go back into my wiring harness??? **** thats alot of work, I never had this problem last summer with my old amp (Alpine MrdM300 V12) but I still couln't get any AM stations at all! But now my radio is working fine and I didnt touch anything just unhooked the amp.
Electric Boogaloo...
Originally Posted by SlimmKidd
The guy at Audio haven said that I might need a Fm signal booster I can get one at canadian tire
I just went and checked about the radio in my Civic becuse I have tryed switching it out and everything. I still have crapy signal. The guy at the sterio place said that the only thing that can be done is to add an esternal ant. to the car and I think there is another way. If anyone can help me out please do. This sucks not haveing a radio half the time.
what if my aftermarket radio does not have the power antenna wire...it has:
blue/white (remote with the label: "please connect this wire to the remote for the amplifier, equalizerand/or auto antenna", which i will be hooking up to remote wire from the amplifier.)
red (accessory)
orange/white (illumination)
yellow (battery)
black (ground)
and then 8 speaker wires
my scoshche harness does have a blue (power antenna), so is it ok to splice in the power antenna wire from my harness into the blue/white remote wire front he radio which is connected to my amplifier?
red (accessory)
yellow (battery)
black (ground)
thats where it would normally go, but since you have an amplifier turn on lead allready connected, that might be too much. It would be safe to connect the blue wire in harness to the blue/white wire coming from your headunit and then connect the amplifier turn on lead to the 12 v power socket wire which is right in the same area. i believe it is a yellow wire, but verify with a DMM before connecting it.
k, one more question...i only have 1 orange/whlte wire coming out of my radio (illumination), but on my harness i have an orange (illumination/dash, which i have hooked up with the radio one), and then i have on orange/white (dimmer). do i connect both of those to the 1 from the radio, or leave the dimmer wire hanging behind? thank you.
Power Antenna Wire? sound weird!
Hi, before do all that check the antenna plug (on the right lower kick panel )there is a joint over there make sure is connected,plus if you are using FM modulator this one gonna lower your reception at least 40%.
Now talking about wiring your radio So far all radios different brands etc. has at least one power turn on wire or most of them have two, one is the Blue and the other one Blue/white.
Now "Power turn on or remote turn on" means the gonna send a remote signal to your equipment like radio,Eq,Amps etc.
"Antenna turn on" means the you use this wire to connect your power antenna to roll up when you use your tuner and off when you turn off your tuner, so I don't understand why thay said that you have to use that wire when our Civics doesn't have a Power antenna!!!won't make any difference on that.
One more thing check your head unit if you have the Local or not local station settings.
Good Luck
A friendly advised on car stereo installaton.
Good Luck
Good Luck
Good Luck
actually, our car has an antenna ampifier on the passenger side c-pillar, when 12 volts is applied to it, it boosts the reception. the antenna turn on inst just used to tell the antenna to extend, but thats what its most commonly used for.
I just went and took off the panel in the back seat and checked the antenna wire and the antenna boost wires. I made shure they were getting power and that everything was hooked up right. Now my radio works better then it ever has. I guess something was just loss. Thanks for the help.
SidCivic
Oct 3, 2015 06:00 AM
Styven Szastur
Sep 23, 2015 05:26 PM
RIPSAW
Aug 16, 2015 12:14 PM
