Enclosure question
Old Mar 28, 2005
Big Rob's Avatar
I'm taking over!
Big Rob has a little shameless behaviour in the past
Enclosure question
Sorry if this question is a little confusing.
For a while, I have been using an enclosure with a single Rockford Fosgate P112S4 (12" punch stage 1 if you don't feel like looking it up) in a ported 1.75 cubic foot enclosure. Now I'm planning to add a second sub to my system and my friend who helped me build the enclosure that I'm currently using told me that we can just take off the front of the box and recut a new piece that can hold both of the subs (since the box is wide enough for two 12" subs). Then he talked about how subs can share airspace. I was wondering if anyone knew how it would effect the performance if you were to compare it to a ported box that has 1.75 cubic feet per sub.
Old Mar 28, 2005
OyD's Avatar
OyD
OyD is an unknown quantity at this point
They can share airspace but they need more of it if you are using 2.
Old Mar 28, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
No, that enclosure with two woofers would sound worse than one. You need much more volume for those puch's, like 2+cu. If you buddy helped you build the first enclosure, he can help you with the second. Of course they share airspace, but what they can't do is share the same volume at the same time. In other words, every time they hit, they can't each utilize the same 1cu, they split it.
Old Mar 28, 2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
I would do separate chambers on the two subs regardless.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
