Q-form kick panels
Old Mar 22, 2005
MegaHurtz's Avatar
Q-form kick panels
anybody have them in their vic? how do they sound? will they fit 6-1/2?
that is all
Old Mar 22, 2005
CtrlAltDel's Avatar
CtrlAltDel is an unknown quantity at this point
i have a set ... brown / tan in color ... universal fit ... bought them for another car but sold the car before i installed them ... never used ... i believe they will fit that size ... not sure
Old Mar 22, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
I have Q-form installed. It really depends on your speaker configuration. But I said before in another thread, it's not plug and play, and lots of experiments are still needed to make it sound good. Take extreme care with your passenger side speaker, since they will always ound louder from upper midbass to upper midrange. The best bet is to have independent gain/output level adjustment or EQ for EACH speaker(SPEAKER, not SPEAKER SET) then it will absolutely sound good.
In my car I have 2-3dB boost on midrange and 5dB boost on upper midbass at the passenger side.....
Old Mar 22, 2005
82801BA's Avatar
I think a 6 1/2 will be able to fit if the frame is not too big. I used to have Alpine SPX-F17M installed in there. It was a 6 3/4 speaker, then I basically trimmed off the 4 edges that sticks out. It fitted perfect. Well, not really for the grill.
In a rare case that the speaker can't fit from the top, then cut off the cone perimeter on the Q-form. I do believe that you can do a bottom install. Just make sure that everything's secured if you are on this track.
UltraHDGames
Jun 8, 2016 05:16 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
