OMFG.. hits himself
OMFG.. hits himself
lol. ok so i was hooking up my first amp
yay to my front speakers. so i started new with wiring the whole damn car (first time)
so amp everything wired. i know my wiring perfect cause i jsut do a lot of it lol
so i ground and power the amp..
nothing
it lights up and such.. kinda. i get red protection lamp
so to me. i think i ****ed it up.
J187 tells me it may be grounding threw the rca's which is enough to light some led's
so anway. tonight on my way home i pop the trunk and detach my ground. i try it in a few places. one gives me a spark. so i knew thats wut it was
so i ram the lil basterd into the latch of my upper trunk part. turn on the system and it works.. now i need to find a proper ground
im an idiot for not testing my grounds
but it woorks
only one major **** up for my first time
yay to my front speakers. so i started new with wiring the whole damn car (first time)so amp everything wired. i know my wiring perfect cause i jsut do a lot of it lol
nothing
but it woorks
Slowest 7thgen in the GTA
You can ground anywhere in your trunk. You need to sand off the paint, otherwise it will not ground. Did you try to ground somewhere with paint on it before?? or now??
Originally Posted by darklegacy540
Congrats.. by the way i'm the one who said it could be grounding through the RCAs you ****. j/k But at least you have it working now and you have good tunes now
haha sorry. sorry. dark gets the credit
j187 had the same idea. if orgot u said it first
but it works. now come tomorow int he light i need to remount the wire properly. and playw ith settings
also. i had my back seats all out. theres a silver metal plate under the seats in the middle. i lifted a screw and mounted the ground i ASSUMED that would be a good ground.. nope
Electric Boogaloo...
Where to ground? Anywhere you feel like scraping, sanding, whatever, removing teh paint and running a sheetmetal screw in there. Make sure you remove all paint. Another option is to go back to the rear (near the latch) of the trunk. Take out the plastic piece. You should see a green ground bolt with about 6 wires attached to it. You can ground on that without having to drill a new hole. There are hundreds of options.
haha i have it grounded. not having a prbolem finding grounds. i jsut assumed wut i had for a ground worked as it was a long screw on bare metal :|
MichaelLW
Sep 14, 2015 07:15 AM
