three light bulbs burnt out!
Old Mar 20, 2005
es2k2's Avatar
Proud to be a civic owner
I just replaced my oem tail light with tyc and right after i installed them, i test the brake lights (without putting all the bumper back) and it works... after everything is put back, the rear brake lights don't work!!!!
well, just the right one at the beginning but then several hours later, i went to check again and want to make sure the signal light is yellow, then i found out the left one is also burnt out!
another several hours, i turned on my car and the headlight, the right headlight is burnt out now! it's piaa super xtreme light bulb... anyone know what's going on... how come all the light bulbs are all burnt out?
is it because of the battery? how much is the honda battery compare to some "good" battery in autzone/pepboys??
Old Mar 20, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
your battery shouldn't be burning out the bulbs. You should probably take it apart again and check your connections. ALso, make sure you weren't supposed to upgrade the wire harness before changing the bulbs.
Old Mar 20, 2005
es2k2's Avatar
i didn't upgrade any wire harnesses...
Old Mar 20, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Well that could be your problem right there
Old Mar 21, 2005
es2k2's Avatar
why i'm using the original light bulbs for the tail lights
Old Mar 21, 2005
juzthewy's Avatar
juzthewy will become famous soon enoughjuzthewy will become famous soon enough
fuses maybe? that a tough one
Old Mar 21, 2005
J187's Avatar
Oh, if you are using the original bulbs then I'd check your wiring.
Old Mar 21, 2005
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Got to be the wiring!
Old Mar 21, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Maybe the bulbs aren't burnt out and you just have a short in the line.
Old Mar 21, 2005
es2k2's Avatar
if there's a short somewhere, i would think all the light bulbs would not be on???
it's not like one at a time by like 2-hour interval...
so none of you think it's the battery problem? i think i'm going to take my car to honda service dept and let me check it out... i don't want to buy a HID and then burn it out...
Old Mar 21, 2005
jttegx's Avatar
OMNES AD UNUM
did any of the bulbs have any contact with dirt or fingerprints (touching it) ?
Old Mar 21, 2005
es2k2's Avatar
i don't think so.. i've been very careful.. i tested it right after i installed them... but after putting all the bumper and the clips... they don't work...
since i was working at my friend's place and when i drove back home, the right headlight is also burnt out... what the hell is going on
Old Mar 21, 2005
Octane Joe's Avatar
slightly off subject, but why did you pull your rear bumper off to change the tail lights?
Old Mar 21, 2005
es2k2's Avatar
mine is a sedan.. there're like 4/5 screws behind the bumper..
Old Mar 21, 2005
dirtySAMURAI's Avatar
I log in from time to time
why are you worried about HID when you're talking about changing the tail lights?
Old Mar 21, 2005
Octane Joe's Avatar
ah, ok, I have 2d, didnt know that, sorry... but yea, I dont know if your wiring runs by the bumper mounts or not, but maby you pinched a wire and the slow burn out is caused by a small short, and the headlight may just be a fluke thing w/ bad timing... dont know, just taking a shot in the dark...
Old Mar 21, 2005
es2k2's Avatar
that's the weird thing.. after i changed the tail light, the headlight bulb burnt out too
i don't want that to happen to a HID if i do get one
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
themechanic
Lighting
Feb 2, 2018 09:23 PM
Lopes101
Jun 7, 2015 08:04 PM
DaPipeLayer
Nov 14, 2001 08:06 AM
disaster
Nov 7, 2001 05:30 PM
