coments on my proposed setup?
Old Mar 17, 2005
paradoxblue's Avatar
ok heres what i am planning on doing. its hopefully ok. let me know what you think
also i wanna do some seperate tweaters upfront. and so such crap cross overs?
need some help
i plan to run a car pc. and a 7 inch touch screen
i will be using a audigy prop usb sound device for my amps
and will hook up a 2 channel amp for my subs and a 4 chanel for the front and rears
i have that muchw orked out and it should sound fine coming from the pc :P so no griping i did lotsa research
but now i wanna figure out how to wire up the fronts and rears?
i know my rears arnt as important. but the fronts i wanna put seriosue cash into.a nd wanna do sperate tweeters in the sail.
ideas?
Old Mar 17, 2005
oh oh
im runnign 0/1 guage qire tot he trunk (i know it could be over killb ut i like ot be prepared)
and iw ill have a 1>4 distro block there with 4 4awg out puts
sound good? and where/wut should i have for fuses?
Old Mar 18, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Ok, your post is a little confusing. I'm not actually sure exactly what you are asking.
My first question is simply why dont' you give onboard sound a shot and see how it works with your system before you spend a) money and b) prescious DC power on an Audigy?
Second question is why a 2 channel amp for the subs, you'd be better off with a mono amp.
About the front speakers, what do you want to know about wiring it? Like you said, run the 4 channel to the fronts and rears.
Old Mar 18, 2005
well i wanna run seperate tweaters up front.
im doing th eaudigy cause i have no where for a head unit. and dont wanna spend 400 on a HU when i can put that towards some car audio stuff. and my pc.
the audigy will be round 100 bucks. wont require any more power then the pc will already be using (or very little) much less then a head unit
ive decided on some 3channel pioneer 6x9 speakers for the rear
but i dontknow what iw ant up front.. HELP :'(
Old Mar 18, 2005
ok i think i may go with these up front
CDT Audio CL-61A 6-1/2" Component System
what do u htink? i hear good things
Old Mar 18, 2005
J187's Avatar
Those were my recomendation in a previous post a little while ago. Good stuff.
Old Mar 18, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Originally Posted by paradoxblue
oh oh
Never overkill bro thats what I did, have not had problems with any electrical system in car!
Old Mar 18, 2005
ex_03's Avatar
Godlike member
As for the sub amp being 2-channel, are you going to compete like in iasca or something because if I remember correctly they give extra points for having stereo sub. but other then that mono for sub and 4 channel is a great way togo.
Old Mar 18, 2005
yeha i htink ill go with mono. i got a 2chanel 1000w for a good price so i have one. (not a top bradn but not horrible)
so im wondeirn gif running a mono amp and two 2chan amps will be ok?
one for the fronts. one for the rears?
my plans consist of a 3 amp rack lol. so i need to work in three :|
Old Mar 19, 2005
J187's Avatar
I run a mono amp for my two subs and a 2 channel to my fronts. I run my rear fill off the deck. If you have deck power, running the rears off the deck a) gives you just about perfect power for rear fill, b) saves you all that money on an amp
Personally, I think it's a little bit of a waste to run the rears off their own amp considering for a proper sound stage, you'd end up turning the gains so low, the amp will be putting up just as much power as a typical HU does. Free power
Old Mar 19, 2005
ahh ok. makes sense. so i should use the 2 chanel i have for my fronts then?
now im just trying to find myself the pieces i need to fit my head units into the dash for now. untill i can get a poper car pc up..
Old Mar 19, 2005
J187's Avatar
I would. I love running the mono amp to subs, 2 channel amp to front components setup. It allows me to spend all my dough on the most important parts of my system, and only have to run 2 amps. Rear fill sounds fine off the deck. I'm even running MB Quart raw 6.5" off my Alpine and it sounds great for rear fill
Old Mar 19, 2005
yeah but im not sure if i will be running a head unit. probably. but need to design a way to mold a car pc and xbox into the setup.. lol
so if i leave the rears factory off the deck..
now wut do the stock fronts run at. the amp i have has this lsited for specs:
max power output = 1000W
power output at 2 ohms 150Wx2ch
Power output at 4 ohms 100Wx2ch
power output bridge 300Wx 1ch
anything else u should know? its a low watta mp. i knew that lol. i was just hoping it would be good for front or rears? and 100-150 is ok for speakers? or no good?
i wanna do up the fronts. as i hope to replace them with compnents soon.
Old Mar 19, 2005
J187's Avatar
Perfect to run it 2 channel to the fronts 100x2@4ohms. If you arent' going to have a head unit, you could always leave the rears out entirely . . . Or just get a real small, cheap 2 channel amp.
Old Mar 19, 2005
ok. sounds good. so is 100watts good for fronts? and will it change the sound of my stocks?
also. if im to upgrade the fronts. will the 100 be ok for them. or do after markets use higher watts :|
im all new to this. but tryin to learn heh
J187 points your way. if i knew wtf rep was. id giv eu that also if i could.
THANKS!
