Where should I mount my tweeter?
Old Mar 8, 2005
  #31
prccivic's Avatar
Originally Posted by WhiteRabbit
well, theres a burr even if the bit is perfect, which cant be easily and cleanly removed, for pure pure flushmounting (I consider that lip still a "surface mount" after a fashion)
as for the koda tweets, Ive put in a pair of those into a sedan hybrid, plenty of space. but no lip. so good luck on that one. measure twice, cut once, its an odd diameter at the surface.
as for pics of my a-pillar ,its not representative. my a-pillar is carpeted, and my tweeter cup is about 1-2 mm wider than the flat surface of the pillar (without carpet) so it wont look anything like what you would end up with.
yes, always measure twice and cut once....and without a lip...it will be alot tougher...good luck though
Old Mar 8, 2005
  #32
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Little FYI for anyone using a hole saw on a plastic panel like a door trim. Use 2" masking tape over the panel before cutting through and cut right through the masking tape. This keeps the plastic from sharding or spliting, also makes for a completely clean hole. I installed frame sliders on my motorcycle this way and it looks completely factory.
mgrantaz
General
May 2, 2022 05:40 PM
twd000
Oct 4, 2015 12:52 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
ZoSoIV
Sep 17, 2015 07:17 PM
FistRock
Sep 4, 2015 08:00 PM
