Those with components...
Old Mar 3, 2005
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
where did you mount your crossovers??? and specifically just for size sake, anybody with Alpine type-s 6.5 components, same question...
if u mount them in the doors where do u do this????
Old Mar 3, 2005
Regularjoe's Avatar
Regularjoe is on a distinguished road
Old Mar 3, 2005
thomusvoo's Avatar
Newbie Member
thomusvoo is on a distinguished road
i would like to know this too
Old Mar 3, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
that is a sweet setup you got Regularjoe. Looks very clean
Old Mar 3, 2005
WhiteRabbit's Avatar
I like putting them in the back like that, but only if they will be exposed. too much wire otherwise.
easy to cram them into the kickpanel area, or hidden up under the underdash.
you can also cut out a touch of that foam inside your doorpanel and put the crossover on top of that. this will save you the trouble of running additional wires through your door. assuming you put your tweets into the door, that is.
Old Mar 3, 2005
jttegx's Avatar
OMNES AD UNUM
i shaved off the stryofoam/yellow foam chunks just enough to fit the crossover for fronts. been few months now and no problems at all. like the stryofoam does much anyways.
the spot where you remove your door panel and that block of yellow foam... thats where i shaved off like 3-4" of.
dont have alpines but they were 6.5" and didnt fit without spacer so i just cut up some wood in circle shape and just used it as spacer. that was no prob either.
goodluck
Old Mar 4, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I put mine in the trunk.. it's kind of a lot of wire to run though but when the whole car is apart, what's the difference?
Old Mar 4, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I got mine in the same place as RegJoe
Old Mar 4, 2005
Excal's Avatar
blah™
Excal is an unknown quantity at this point
I ziptied mine inside the door on the wiring harness right above the speaker. It just rained yesterday and i checked last night when it wasnt raining to see if it got wet and no water on it. And i got the Alpine sps-171a's just put them in last weekend.
Old Mar 4, 2005
eye_see_you's Avatar
let the devil out
right now my x-overs are inside the door panel zip tied inplace but when I place the new kicker SSMB6 components in i'm glassing the door panel pocket to have it mounted in along with the new 6" so it will be exposed for view or maybe behind some plexi.
Old Mar 4, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
if ur just trying to hide it put them behind the door panel. thats what i did. I used a backstrap and wrapped it around the crossover and screwed the backstrap to the metal on the door and velcroed the crossover to the backstrap. U dont see it and it doesnt bounce around or anything like that. I have Diamond Audios 6.5" components $450
Old Mar 4, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
Mine are on my amp rack in the trunk
Old Mar 5, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
I have allways mounted them in the car never the door, you've got to remember that you open and close your door how many times a day + moisture is allways a factor, inside allways a safer cleaner install.
Old Mar 7, 2005
OyD's Avatar
OyD
OyD is an unknown quantity at this point
It there any negative effect from mounting the crossovers in the trunk as far as sound quality or loss of power, etc.?
Old Mar 7, 2005
djspot's Avatar
fuk tha man!
how do u like them, compare them to the stock speakers...I have my stocks amped and Im amazed they've lasted a year already...they honestly arent TOOO bad...
Old Mar 7, 2005
Excal's Avatar
blah™
They sound great...I just havent gotten a chance yet to really sit there and tune them completely to my liking. But they was easy to install and like i said sound great way better then stock.
Old Mar 7, 2005
ex_03's Avatar
Godlike member
None that Im aware of.Just becuase the wires will be lengthier your not going to loose anything.
Old Mar 7, 2005
ADS's Avatar
ADS
ADS is an unknown quantity at this point
my alpines are mounted in the doors some saving of the foam was required and make sure u secure them properly....more than a zip tie because mine broke the first time because of it now i have soundstream and i mounted them in the same place
Old Mar 7, 2005
AlpineCivic's Avatar
Well I have Alpine Type-X and my crossovers are in the Trunk.....If you want to keep them in the door, well, I used to wrap them in plastic and tape them up in order for them not to get wet, and hot glue or double side tape them to the bottom of the door where their out of the way.
jennyak
May 9, 2011 04:55 PM
Eyger
Engine Swaps
40
Jan 12, 2009 01:57 PM
vietfob714
Nov 28, 2006 04:49 PM
steven10
Aug 16, 2006 04:40 AM
steven10
16
Jul 26, 2006 04:40 AM
