anyone done this to rear speakers?
Old Mar 3, 2005
I was thinking of buying those foam cups, putting a back wave distortion pad at the bottom, and slipping it over the speaker. Would it make them sound better?
Old Mar 3, 2005
Ed's Avatar
Ed
I've been thinking about doing that as well, well, for the front guys mostly. I don't do much with the rears, but I hear you can get those foamy things, and even fiberglass them, and they'll get stiff.
i hear that can help with bass response sometimes. where are you going to get them at, i'd give them a try up front for sure.
edit..hmm, i was googling a little:
http://www.caraudioforum.com/vbb3/ar.../t-210732.html
Crutchfield says "Waterproof foam baffles fit behind your speakers to keep them clean and dry, and to improve your bass response. They compress easily to fit the installation area. "
Old Mar 3, 2005
www.partsexpress.com has all the parts. I already put that dynxorb stuff behind the door speakers to reduce distortion and it helped alot. Just looking to do the same to the rear. The dynxorb wouldn't really work for the rear. That's why I was looking at those circle things that can be held in the cups.
Old Mar 3, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Idoubt that will do much. Any back waves will be fired into your trunk carpet or carpet/wood on your sub box. Both things tend to suck up vibrations pretty well.
Also, did you remove your trunk springs? If not, you would have to.
Old Mar 3, 2005
kornsined's Avatar
rear speakers suck. i disconnected mine and only use front components. for some reason in our cars it sounds so unbalanced. this is using subs for bass of course.
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
jpat21
Sep 3, 2015 11:32 PM
jpandjf
Aug 3, 2015 05:02 PM
Nalmonte
Jul 22, 2015 09:08 AM
