Hid
Old Feb 24, 2005
02CivicRider's Avatar
02CivicRider is an unknown quantity at this point
Hid
how hard is it to install the xtech hid kit?
Old Feb 24, 2005
LiKEaFeRiO's Avatar
If you can tie your shoes you can install it.
If you didn't learn to tie your laces and got stuck with velcro...you can still install it.
Old Feb 24, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
just like chaning your regular bulbs, cept for a few wires running out of the ballasts
Old Feb 24, 2005
that simple huh?
Old Feb 24, 2005
Originally Posted by 02CivicRider
that simple huh?
Never has HID been so plug and play
Old Feb 24, 2005
well, depends.. H1 (projector headlights) or H4 (stock headlights)... if you got H1's you gotta open up the hole a little to accomodate the HID bulb by drilling, filing, etc...
Old Feb 24, 2005
FALKEN's Avatar
Civicforums Junkie
easy install
Old Feb 24, 2005
yeah cause i got the h1 projectors
Old Feb 24, 2005
yea.. its kind of a bitch to file out the hole... when i did it, i ended up getting metal flakes all up in the headlight assembly.. take your time with it and you'll be fine..
http://www.7thgencivic.com/forums/sh...&page=32&pp=15
post 469 will give you an idea of what to do..
http://www.7thgencivic.com/forums/sh...&page=27&pp=15
you can also look through this part of that thread to get a little guidance...
Old Feb 24, 2005
well im not to worried about the headlights honestly. the right halo just went out and now it works when it wants and then it wont and then it will flicker and stop. its stupid kinda a waste of money, but will having the projectors make the headlights brighter then the factory headlights would.
Old Feb 24, 2005
FALKEN's Avatar
Civicforums Junkie
i ended up getting metal flakes all up in the headlight assembly...
you could have used a vacuum while filing to suck up the metal flakes
Old Feb 24, 2005
FALKEN's Avatar
Civicforums Junkie
next to an OEM projector retro fit, the stock OEM housings are the brightest/easiest install
Old Feb 25, 2005
really. i guess well see what happens
Old Feb 25, 2005
i would have, if i had one available... got all the flakes out of there when i did a retrofit
Old Feb 25, 2005
ImPulse's Avatar
takes me literally 10 minutes to install a whole kit...
Old Feb 25, 2005
how long do you think it will take for someone who never done it before like me?
Old Feb 25, 2005
Soon2BeGrlRacer's Avatar
Soon2BeGrlRacer will become famous soon enough
The first time and only time I installed a hid kit it took literally 5 mins plug, and about 25 trying to find a comfortable/safe spot for the ballasts.
UltraHDGames
Jun 8, 2016 05:16 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
Voiceofid
Feb 3, 2002 03:54 PM
