factory speaker upgrade
Old Feb 23, 2005
02CivicRider's Avatar
02CivicRider is an unknown quantity at this point
i dont know a whole lot about stereos, but if you are to upgrade your stock speakers to new ones no you need to run an amp with them or will they work good with the factory wires? i already have a head unit and subs, but i want to upgrade all the speakers.
Old Feb 23, 2005
Ed's Avatar
Ed
I'm not really sure what you're asking.
If you put in new speakers, unless you're running a ton of power, in most cases, teh stock wiring is fine.
You don't need a separate amplifier [although it's recommended, atleast a small 2 channel for the front], the HU should be able to power it alright. This also depends on which speaker you choose as well. Some sound better than others with less power.
And, just as a personal note, I'd suggest spending a little more on just a nice pair of front speakers and a 2 channel amp, while leaving the rear stock speakers powered off the HU.
Old Feb 23, 2005
tom1178's Avatar
tom1178 is an unknown quantity at this point
That depends on how much $$$ you want to spend and how good you want it to sound. For starting out, you can just buy new speakers and they will definitely sound better/last longer than your stock ones, if you want it to get any better from there, then go out and spend the $$$ on another amp/wires/everything else involved in upgrading. It's all a matter of personal preference but you will notice a difference after switching out your stock speakers.
Old Feb 23, 2005
well ive got all the money. my whole system is fosgate so i want to stay with that. so you think i should run an amp with the front speakers and leaving the back with the hu?
Old Feb 24, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
I'd stay stock in the back, and ran off the HU to keep from drowning out the fronts, and throwing off the imaging (which is horrible in the stock location, I digress). Unless you get new fronts with a low rms rating, why waste money getting new speakers to run off the deck? The stock speakers are designed to run off of deck power, theyl'[l sound as good as any other speaker you put in there off deck power. Definantly amp new speakers.
As for fosgate components. Their components are lacking very much in teh midbass department. I've seen several sets of different lines, every one of them reminded me of infinity's, piercing highs, and lacking mid frequency flexability. You can go with their components, sure, but is brands matching that big of a deal? You're not going to see them anyway, unless you take the grille off the door. I'd go with something else to cover sub to tweet gap.
Old Feb 24, 2005
what do you suggest then?
Old Feb 24, 2005
Music tastes would determine that. Also budget, and SQ or SPL system?
Old Feb 24, 2005
i listen to everything but country. no offence to any country listeners. but budget is no problem. what is SQ and SPL?
Old Feb 24, 2005
SQ= Sound Quality
SPL= Sound Pressure Level (focused on getting loud with no regard to clarity)
jdh022764
18
Nov 3, 2015 06:44 AM
Gsxtacy
Sep 12, 2015 01:09 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
