Fabricating a touch screen into the dash
Old Feb 21, 2005
  #31
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Originally Posted by PopcornPlaya
PRICIVIC. That's very easy. Especially a 7 inch. You can buy the dash piece (if youre worried about fuxoring your stock one) frmo majestic honda for about $65 shipped, if I remember correctly. Easy to fabricate there.
J, Looking good, what you gonna open the hole up for the buttons with? Dremel with fine bit?
Survey says . . . Dremel w/fine bit #1 answer!
Old Feb 21, 2005
  #32
HEBEGEBZ's Avatar
HEBEGEBZ is an unknown quantity at this point
Is that your final answer? LOL
Old Feb 21, 2005
  #33
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
<3bondo glass<3 stuff bonds like a champ to plastic
</3sanding bondo glass by hand</3 omfg it takes for ever
<3dremel<3 greatest tool ever
its lookin good cant wait to see it finnished
Old Feb 24, 2005
  #34
J187's Avatar
Actually, I'm gonna cut the buttons. 3 reasons:
1. In order to keep the buttons showing through enough, the bondo/glass would have to be so thin that it's starting to jack with the smooth contours of how I want the dash to look.
2. If I move the screen forward any more, it won't be recessed at all.
3. Overall, I think it's a little too busy looking with all those useless buttons. I am going to keep the IR sensor and Some method of power on/off. Either the button itself, or a tiny hole to push the button w/ a paper clip like an eject hole on a CD ROM drive. If I get some pics in a little while of how busy looking it is, I'll thow em up.
Old Feb 24, 2005
  #35
HEBEGEBZ's Avatar
^^Please do because i thik the buttons would look really good down there. i guess i just have to see it to really have an opinion.
Old Feb 24, 2005
  #36
teampointless's Avatar
Ultimate Member
lookin good so far. i thought it might look crowded with the buttons... keep us updated.
Old Feb 27, 2005
  #37
J187's Avatar
As you can see, I've decided to keep only the power button and IR Sensor.
I also trashed square edges and rounded em' off. Looks much more natural IMO.
Old Feb 28, 2005
  #38
PopcornPlaya's Avatar
Electric Boogaloo...
You gonna smoth out that lip at the bottom?
Old Feb 28, 2005
  #39
J187's Avatar
Yup, already did this morning. I basically primed it with spot filler so I could gauge the high points - the lip was invisible in the bondo-bondo/glass-putty camoflauge. I puttied some more spots and getting ready for the final prime. Then paint.
Funny too how the flash of the camera relected off the wet primer making some wierd illusions in the lower pic.
Old Feb 28, 2005
  #40
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
I like using a plastic weld like re4040 to mold screes in. Much easier and less time consuming.
Old Feb 28, 2005
  #41
audioefx3's Avatar
now after looking at the pics on pg two Im kinda chuckling to myself. You created alot more worked for yourself mixing bondo and fiberglass Ill have to post pics of my dash peice its all primed wetsanded and ready for paint with a 7in exonic mobile screen
Old Mar 1, 2005
  #42
J187's Avatar
Chuckle all you want but I didn't "mix bondo and fiberglass together" the mixture comes that way. Furthermore, I didn't make ANY additional work for myself considering I needed to fill large gaps to get the contours right. Strength wise, its allways better to build up with fiberglass and cut down than to try to get just enough of a coverage area. Also, I use a pneumatic DA so the bondoglass which you see in pg 2 was reducecd to the finely shaped contours you now see in the primed pictures in a matter of say, 4 minutes. Not sure if you've ever tried to build considerably with 2 part plastic but I'll tell you this, It bonds things way way better than it forms things. And it's forming capabilities are far inferior to fiberglass or bondo. Also, products like duramix 4040 aren't nearly as strong as fiberglass and are absolutely no faster to use.
Please explain to me how you can install your Plastic tube into a caulking gun, tip it and mix it in much less time than it takes someone to mix some tiger's hair with creme hardner (about 18 seconds). Also, if you've found another way to install screens, that's great! Just put up some pics and share em with us. Hell, even suggest the way you did it and what worked for you. But don't laugh at anyone else's efforts when you don't know what the hell you are talking about.
Old Mar 1, 2005
  #43
J,
This guy's been foraging through threads trying to argue with someone. I'd be willing to wager that he's never fabricated anything in his life. Just some random stuff that's been read and passed along as myth from forum to forum like a lot of things do. Anyway, keep up the good work.
Old Mar 1, 2005
  #44
J187's Avatar
Thanks. I got a little testy there, huh. Anyway, I should have finished pics tomorrow.
Old Mar 1, 2005
  #45
audioefx3's Avatar
ok whatever I used to work at a shop and my brother now owns a shop and graduated from mobile dynamics. You dont have to believe me I dont care Im just trying to offer suggestions not trying to start fights. Your way is a good way to do it dont get me wrong but I have the pretty much same piece at my brothers shop that I made myself(except for a little bondo work). I didn't cut the plastic at all just removed the bezel that used to hold my head unit and my screen fit right in. I removed the plastic from the screen itself cleaned the plastic and layed it flat on the table with the frame of the screen in the position I wanted it. I used re4040(you buy a cocking gun that is specialy made for there products) and I filled in the gaps. Then I light sanded the plastic only then I had one of my brothers installers smooth it out a little with bondo and then rage gold extreme. I shot the primer with the aigun and sanded-did that twice then I used bulldog brand primer then started wetsanding and now its ready for paint.
I'll admit im far from an expert but I have picked up **** over the years mainly from my brother and installers that work for him. I have worked with bondoglass I just dont like to sand fiberglass it makes me itch all over.
I didn't think you guys would take offense to what I said so Im sorry if you did. Popcornplaya I never directed any commet towards you and you saying I havent ever fabricated anything is cool with me because Im not really into systems my brother is its just **** I picked up because he in the business and I do biuld everything that I put in my personal car and I work at the shot sometimes when they get swamped.
If you guys want me to leave the fourm just say if and Ill part my way
Old Mar 1, 2005
  #46
HEBEGEBZ's Avatar
audio, i think this is just a case where you used poorly chosen words to express yourself. I have to admit I was even ready to say something in J's defense, until I read your last post. This type of thing happens all time here. I am sure there are no hard feeling. Lets see pics of your screen.
Old Mar 1, 2005
  #47
thekuai's Avatar
thekuai will become famous soon enoughthekuai will become famous soon enough
so whats gonna be the source unit for this indash? dvdplayer? can you get a gps unit to work with this screen?
Old Mar 2, 2005
  #48
J187's Avatar
TheKuai, actually it's for a full fledged computer running winXp in the making. I'll keep you posted.
Audio - I'm actually a very nice guy, as you explained you werent' trying to take digs, just offer another view, I'm happy to hear what you have to say. I'd love to see your project too. You should probably take Hebegz post as the most important thing here, it was strictly the way you presented yourself. For instance, you got a buddy working hard on something but doing it the wrong way while you watch, do you burst out laughing (chuckling) or do you constructive tell him you might now of another way . . .
No big deal, just thought you were on offense there, you know. Anyway, start another post and throw up some pics of your proj, if your bro owns a shop, I'm sure the work will be banging and we'd all love to see it.
BtW, there is now possible way that you used the same screen I did and did not cut plastic to fit it, so it's kind of a moot point that I had to cut the plastic. Also, how is bulldog primer, I think I've heard good things about and if it is the brand my friend uses, I've been meaning to give it a try - I like primer with good filling properties a little bit on the light side.
Old Mar 2, 2005
  #49
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
HD carry fg mats that more suitable to these type of work instead of raw glass fibers.
its easier to work w/, just cut to shape and apply resin/hardner.
Old Mar 2, 2005
  #50
audioefx3's Avatar
yea thanks guys I did come off the wrong way and Im glad you saw through that and accepted my applogy. Im gonna take the digi to the shop today or tomorrow and start a separate thread with pics of my work and the shop car. J187 i read that you are going use the screen for a computer setup. That sounds pretty sweet. Our shop car is equiped with a mobile linx computer system(thank you mobile linx-sponsor-) and having a computer in the car is very trick. Can't wait to see some finished pics of your project
Old Mar 2, 2005
  #51
audioefx3's Avatar
ooh sry about the bullgog my brothers partner loves the stuff but it is my first time with it . I only have experience with a couple brands of primer and the bulldog seems pretty good so far. Also there paint adhession spray for plastics is ****.
Old Mar 2, 2005
  #52
One more time for the reading impared. He's using Bondo-glass. That's bondo with fiberglass fibers mixed already. It applies and mixes like bondo with added fiber strength. Tiger hair is another name for it. Yes, laying up is strong, but for thie project it wan't necessary, plus he had some left over from teh other project, so why waste it?
Old Mar 2, 2005
  #53
J187's Avatar
Painted and just the way I wanted it. I kept the IR Sensor and the power button. I lost the pics w/ all buttons so until I find those, your just going to have to take my word for it that it looked a little busy!
Old Mar 2, 2005
  #54
audioefx3's Avatar
looks great. Nice work
Old Mar 2, 2005
  #55
J187's Avatar
Thanks, can't wait to put the screen in. hope that goes well . . .
Old Mar 2, 2005
  #56
genx_7's Avatar
genx_7 is an unknown quantity at this point
Damn very nice! do a complete DIY when you finish!
Old Mar 2, 2005
  #57
Caucasian.Asian's Avatar
i'm with him, i would love to learn how to do something like this.
Old Mar 2, 2005
  #58
el_ben2's Avatar
CivicMexicano Is My Daddy
el_ben2 is an unknown quantity at this point
wow really... really cool
gonna try it
Old Mar 2, 2005
  #59
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
cool stuff, i like how u always have tons of pix!
Old Mar 2, 2005
  #60
jmiester96's Avatar
jmiester96 will become famous soon enoughjmiester96 will become famous soon enough
can't wiat to see the finished product.
