Radar/ Laser Scrambler
Old Feb 12, 2005
sevgenic's Avatar
sevgenic is an unknown quantity at this point
Question Radar/ Laser Scrambler
How do wire the power cord so that the radar/ laser scrambler or detecter goes on when you turn your car on? So, instead of using the power outlet, wire it directly into the vehicle inginition. Does anyone know how to do this?
Old Feb 12, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
Most radar detectors will have a hardwire kit available. If you dont use a kit to do it, chances are you are going to have to cut apart your power cord that came with it, figure out which is + and - and then tap a + source that is switched with the ignition. You could tap the cig lighter power, that is most likely the easiest one to access.
Old Feb 13, 2005
sevgenic's Avatar
Thanks for the info! Sweeett..
Old Feb 13, 2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
I think you could wire it to the dome light, and have it come on with the slide of selector switch. I have it that way in my non-7thgencivic. Just a theory for now, until I actually attempt it in my g/f's 03 EX.
Old Feb 13, 2005
kornsined's Avatar
very good idea^^^^this way you could still turn it off.
Old Feb 13, 2005
zachgeyer's Avatar
good idea to fry out car
Old Feb 16, 2005
Mystic3030's Avatar
Uhm...wouldent that make it so the radar detector is only on if your dome light is on?
Old Feb 16, 2005
thejdog's Avatar
thejdog is an unknown quantity at this point
You could go buy a switch, not use the one from the dome light.
jDoG
Old Feb 16, 2005
Mystic3030's Avatar
That would be so ghetto...why not just use a relay thats tripped with an ignition wire. That way it will turn on with the car, and if you want it off, you can use the power switch on the detector.
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Donahue
Sep 8, 2015 09:00 AM
carid
Aug 8, 2015 05:05 PM
civicvtec1ps
Sep 4, 2003 08:19 AM
