Would you recommend a capacitor?
Old Feb 17, 2005
  #31
PopcornPlaya's Avatar
Electric Boogaloo...
Originally Posted by xwarp
i did not come here to look for an argument. i'm just trying to explain that a cap will not increase voltage or current from your battery or altenator. if your system dims your lights and and you put a cap on it, it will reduce the surge, not eliminate it. the surge will still be there, but not so much visible. but say your happy with that. would you think you will be able to upgrade your amps and speakers and not be back to square one?
No, I wouldn't buy a cap at all, personally. The cap is feasible in the situation the thread describes because A) the person is wanting to combat dimming. B) he's wanting to do it by as cheap a means as possible. Caps are cheaper than a battery, most of the time. If it were me, and I were buying a cap (which I'd never do,but for the sake of the topic say I am). I wouldn't buy just what I need (.5 farad per 500 watts. So a 1 farad because I'm leveled just below 1kw). I'd buy double or triple the farads generally used/recommended because I like headroom. Gives me space for expansion. Having more isn't going to do anything to the amps, it's not going to increase the voltage, etc. So I'm good with a solid 3 farad cap on my 1kw load, but I'd have room to run up to 3kw, should the need arise.
Another thing to take into consideration, and possilby the most point worthy I'll make: You're on a Civic Forum. 95% of the people here aren't looking to spend a ton of money on their car. They are looking for the cheapest way out the majority of the time. Caps and/or battery would be the easiest way out in this situation.
Old Feb 17, 2005
  #32
xwarp's Avatar
xwarp is an unknown quantity at this point
good point!
solarpunk70
Apr 12, 2016 11:43 AM
twd000
Oct 4, 2015 12:52 PM
MamaBear2015
Sep 27, 2015 06:31 PM
