Orion HCCA 225
Orion HCCA 225
hey guys i got a bad *** deal on one of these,but i have heard good and bad things about them.are they good?any what kind of 12s u recommend with it. thx
what series HCCA 225 is it? The 225R or the Digital Refererence? Either way, the amp will push around 600 watts RMS at 1ohm. The only problem with the amps, mine anyway (I have a 250R), is that they like to get pretty hot. Just make sure you keep them in the open.
So you are looking for two 4ohm dual voice coil subs that can handle around 300 watts. Depending on the sound you are looking for, I would look into IDQs or JL 12w3s.
definitely go with the jl. the orion h2s are junk, imo. even better, find an orion hcca 12d. it will blow your mind. I have an orion hcca 10d and it hit harder than my 2 jl 12w6s v1 did. the only thing it is lacking is the low end of a typical 12 inch sub
USCGBM
Aug 12, 2015 04:22 PM
