building a sub enclosure
Old Feb 7, 2005
craiger's Avatar
craiger will become famous soon enoughcraiger will become famous soon enough
I started to build my 1.4 cu. ft. box yesterday. The only problem is I suck at cutting up the mdf board. I only got one piece cut out and one side is a wavy. It goes from the length it should be to an 1/8th of an inch short on one end. If I would caulk it on the inside and use wood-filler on the outside to fill in the gaps, will I run into any problems?
Is there any suggestions on saws to use, besides a jiggsaw? Would renting a table saw be the way to go?
Old Feb 7, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Table saw will most definantly give you a straight edge. You could even use a skillsaw, with fine blade, and make a guide for it by screwing, clamping, etc a board such as a 2X4 where the guide is and lines up with the line you draw (hard to explain).
Old Feb 7, 2005
craiger's Avatar
I know what you mean about the guide. I will try that before I go out renting anything
Old Feb 7, 2005
Ed's Avatar
Ed
I agree, a sawboard is the way to go with a jizsaw or circular saw. my issue with jizsaws is the inability to cut a perfect 90 degree angle with the blade bending and such. It's great for rouch circular cuts though. I prefer the circular saw for straight cuts.
Here's a site about sawboards, if you're bored
http://members.aol.com/woodmiser1/sawbd.htm
Old Feb 7, 2005
Pun intended?
Old Feb 7, 2005
craiger's Avatar
after trashing my basement, breaking various objects and taking a 15 minute break... I have come to the conclusion that jigsaws suck and that a circular saw with a 4' level clamped to the mdf board is the way to go.
Old Feb 7, 2005
MegaHurtz's Avatar
Originally Posted by PopcornPlaya
Pun intended?
haha good ol geek humor if that is the case :P
Old Feb 7, 2005
Ed's Avatar
Ed
If you have time, and plan on cutting more, I think a great way to do it is to get a 1/4" thick aluminum rod and countersink/screw it to a board, it makes for a very nice saw board.
saw... bored of course
Old Feb 7, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Jigsaws don't suck. They serve a great purpose. However, your using it for the wrong purpose. My electric shaver kicks ***. I wouldn't cut my lawn with it though. Jigsaws arent' designed for cutting straight, even lines. Unless you make some sort of errrr, Jig. Pun intended.
Old Feb 7, 2005
angelswin's Avatar
angelswin is on a distinguished road
I wouldn't say jig saws suck either since I used one to completely build my 1.5 cu ft box that houses a Kicker L7.Just like they said you just use a guide using a straight edge and you should be alright.
Old Feb 7, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Check out your local high school's wood shop. Pay some kid ten bucks to cut them up for you at the dimensions you need.
Dave Brabant
20
Oct 6, 2015 12:44 AM
