Hole in the firewall to run wires..
Old Jan 29, 2005
Profoxcg's Avatar
Profoxcg is an unknown quantity at this point
WHere the hole in the firewall to run wires for power for subs and for gauges?
I found on close to the pasanger side at the bottom, but I was wondering of there is anyother one to use , or if you guys just drill anywhere?
thanks
Old Jan 29, 2005
SiG's Avatar
SiG
I used the one you found, works perfectly!
Dont drill!
Old Jan 29, 2005
Profoxcg's Avatar
does anyone have a drawing that shows all the openings on the firewall?
Old Jan 29, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
i hear you can also go through where the throttle/brake cables come through
Old Jan 30, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Why wouldn't you go through that grommet? It is there for a reason with the rubber around it. It's central to the battery, and also easily tucked away. You can always drill, but I'd say to first spray some rustoleum, or other rust proof paint on the opening once you get the hole drilled. Then I'd silicone around the wire to keep moisture out of the cabin.
Old Jan 30, 2005
Bires's Avatar
Bires is an unknown quantity at this point
That's a great location for your power lead. It allows you to easily go under the carpet and back to the trunk.
Old Jan 31, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
my 2k1 ex coupe had the passenger side grommet in the DIY - but was NOT predrilled. I ended up sharing the central hole nearer to the steering column.
Old Jan 31, 2005
takumi's Avatar
takumi is on a distinguished road
Pics:
It's all the way to the left in this pic:
Closeup:
Old Jan 31, 2005
Profoxcg's Avatar
yep that is the one I used
Old Jan 31, 2005
jttegx's Avatar
OMNES AD UNUM
Originally Posted by Takumi
Pics:
Closeup:
hey takumi, do you have more photos of the firewall? i need to save these when i install an audio system
thanks
Old Jan 31, 2005
koolaidman's Avatar
koolaidman is an unknown quantity at this point
thanks
yes drill holes in ur bulk head
and dont forget to tighen the lose nut behind the wheel
danace99
23
Jun 28, 2015 08:49 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
Dmitri
123
Oct 13, 2005 08:01 PM
mikalem
Jan 5, 2002 10:21 AM
Aznnp77
Dec 9, 2001 08:19 PM
